Output from automation script on Visual Overview open
Solved1.84K views16th March 2022Automation Visual Overview
Robin Becker [DevOps Member]1.42K 16th March 2022 0 Comments
With the Execute page level shape data combined with SetTrigger=ValueChanged and the ExecuteSetsOnInit option I can get a script to run when opening the visual overview (confirmed by logs). However the variable that should contain the output (using engine.AddScriptOutput) from the script is not populated. Triggering the exact same script from clicking a shape-button in the visual overview populates the variable as expected.
How do I get the output into a variable from an automation script running on card open?
Robin Becker [DevOps Member] Selected answer as best 16th March 2022
Robin Becker [DevOps Member]1.42K Posted 16th March 2022 0 Comments
Troubleshooting showed that this only works with a scope of CardVariable and broader. I was using PageVariable and while it worked when triggered by button, it did not work when running on visual overview load.
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 16th March 2022 3 Comments
Hi Robin,
Is it possible that your shape-button defines option cardVariable or pageVariable, while this one isn’t defined on the page options?
If these are the same, can you try by adding option SetVarOnFail=true on page level?
Robin Becker [DevOps Member] Posted new comment 18th March 2022
Robin Becker [DevOps Member] commented 16th March 2022
This didn’t solve it directly but helped me with the troubleshooting.
Jens Vandewalle [SLC] [DevOps Advocate] commented 16th March 2022
Does this mean that you found a way make it work?
Robin Becker [DevOps Member] commented 18th March 2022
Kind of. See other answer for details.
