Obtain Latency between 2 L3 devices withing Datamine.
Solved817 views20th February 2026latency
Divagar Vijayarangan [DevOps Advocate]50 17th July 2025 3 Comments
Hi
I have two L3 switches with specific vlan and IP address. Both switches can ping each other .
Can I capture the historical RTT, latency data between the two switches using Dataminer / code / scrip ?
thanks
Divagar
Jason Boon [SLC] [DevOps Member] commented 17th July 2025
Hi Divagar,
This is certainly possible. My first suggestion is to explore whether the connector for your switches support ping functionality. That way the ping results can be trended.
Hi Divagar,
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select Michiel's answer (using the ✓ icon) to indicate that no further follow-up is needed?
Marieke Goethals [SLC] [DevOps Catalyst]7.33K Posted 20th August 2025 1 Comment
Hi Divagar,
I see that this question has been inactive for some time. Have you been able to resolve this based on Jason's suggestion? If yes, could you select this answer so the question is closed and it's clear no further follow-up is needed?
Divagar Vijayarangan [DevOps Advocate] Posted new comment 20th August 2025
Divagar Vijayarangan [DevOps Advocate] commented 20th August 2025
Hi Marieke
We are using Cisco C9200, but I couldn’t find the connector for this model in the catalog, so I couldn’t check further. Any further suggestion would help.
Thanks
