OB Equipment monitoring
Solved1.61K views27th June 2025monitoring outside broadcast
Camille Cameron [DevOps Member]60 31st October 2024 3 Comments
Hi, We are looking to create an app like the one below for broadcast equipment to be used on OBs. I believe the app below was created in node red. Our operators prefer a visual view rather than text based alarms, do you have a recommended app that you can suggest or would it be better creating this type of app from scratch?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th June 2025
Ian Harvey [SLC] [DevOps Member] commented 1st November 2024
Hey Camille, tackling the challenge from a user perspective is the way forward. Good news, the components used at Empower are the same ones that will enable a dashboard to be built from scratch.
Can we have a sync next week and walk through a similar page built for disk monitoring from a user perspective:
https://ziine.skyline.be/app/95931152-850f-40c2-8811-6e3a4ae60988/Disks
We can support you in building a targeted LowCode application for OB monitoring 🙂
Hi Camille,
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th June 2025
José Silva [SLC] [DevOps Enabler]2.13K Posted 12th December 2024 0 Comments
Hi Camille,
I would also suggest taking a look at this question:
Dynamically show parameters as objects instead of table view in Low-Code App - DataMiner Dojo
Kind regards,
