Node-Edge : How can I draw 1 line between my switches instead of 4?
Solved3.46K views13th September 2021Dashboards node-edge
Jens Vandewalle [SLC] [DevOps Advocate]10.09K 10th September 2021 0 Comments
In Dashboards I'm using the node-edge component to visualize my network of leaf (blue) and spine  (purple) switches.
Now I want to only see 1 connection between my leaf and spine switches, even when there are multiple physical connections between them. What do I need to add to below query to achieve this?
Note that I still want to see the multiple connections between my spine switches.
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 13th September 2021
Gilles Bara [SLC] [DevOps Advocate]7.39K Posted 10th September 2021 0 Comments
The query for the singe connection can be done like this. You just need to provide a unique key for a single line. In this case this would be "Source Element ID-Destination Element ID". Then some aggregation magic will filter out the duplicate rows. And with some regex operation you can extract the source and destination IDs.
For the one where multiple connections are still required you'll need to use another query. And change the node-edge configuration to define which query needs to be used between what nodes.
