Node edge – Conditional coloring – Set Analytical as default
Solved2.48K views20th April 2022analytical conditional coloring edge Node edge graph node-edge
Sebastian Ulloa [SLC] [DevOps Advocate]2.24K 19th April 2022 0 Comments
Is it possible to set the Analytical coloring as default for the entire node edge visualization? After setting it up, I have to manually change the edges coloring. See an example where there are still some edges under the Static coloring:
Thank you!
Sebastian Ulloa [SLC] [DevOps Advocate] Selected answer as best 20th April 2022
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.46K Posted 20th April 2022 1 Comment
Hi Sebastian,
The configuration is saved per combination of node types. This can indeed mean that you need to set it several times (once for each combination). Once set, it will be applied immediately, even after refreshing the page.
Sebastian Ulloa [SLC] [DevOps Advocate] Posted new comment 20th April 2022
Sebastian Ulloa [SLC] [DevOps Advocate] commented 20th April 2022
Thanks Sebastiaan! I thought that it had be set every time the node edge component reloaded, but it was just a different combination of node types that was missing the coloring.
