Node edge – Conditional coloring – Selected node color
Solved411 views6th November 2025LCA node-edge
Enver Podgorcevic [SLC] [DevOps Advocate]136 4th September 2025 0 Comments
I have a node edge graph where I want to conditionally color nodes based on a `Severity` column of my data source. I have set each node type coloring to Analytical, and also set the colors for each possible value of the column.
However, doing so has changed the default selected-node color to #000000. Now whenever I click on a node, it's color changes to black.
Is it possible to have `Analytical` coloring without also having background color of the selected node changed?
Gilles Bara [SLC] [DevOps Advocate]7.17K Posted 18th September 2025 0 Comments
Hi, this isn’t really possible in analytical mode. In this mode, the default color automatically changes to either black or white, depending on the assigned background color. To ensure a clear visual distinction between selected and unselected states, the colors are always inverted. This means that a selected node will use the analytical color as the foreground, while the font color is applied to the background.
