Nevion Virtuoso NX4600 – Auto/Manual switching alarm?
Solved1.66K views9th December 2020
Mark Woodyatt [DevOps Advocate]515 8th December 2020 1 Comment
Hello All,
I am trying to find the alarm in the Alarm Template that will trigger when a Nevion NX4600 Input Switch is changed from being in Manual to Automatic (time stamp 20:22:36 above). But cannot find it? Any ideas please?
Mark Woodyatt [DevOps Advocate] Selected answer as best 9th December 2020
Mark Woodyatt [DevOps Advocate] commented 8th December 2020
One of our team found the parameter – Manual Mode (TS Input Switch Input).
Thijs Vanovenacker [SLC] [DevOps Advocate]2.71K Posted 8th December 2020 1 Comment
Hi Mark, Good that you guys found the respective parameter.
Note that you can use the search bar above the page layout in your element card.
This search can assist you in finding parameters across all pages.
Once you identified the table or the parameter, by drilling down you simply enable alarming/trending from within the card.
Hi Thijs, Thank you. The problem was knowing what the parameter was called. But one of the team found it eventually. Rgds, Mark
