Need a help to find out set / get value on nimbra element
Solved1.83K views18th July 2023
Divagar Vijayarangan [DevOps Advocate]50 22nd October 2021 0 Comments
Hi Everyone
Need a help to find out set / get value on nimbra element. We are planning to have a visio view for our client when they can enable and disable the services on own.
I can see option to disable and enable the ets on element . But want to find out this value to add in Visio. Any ideas on this ?
Thanks.
Diva
Maxim Bouckaert [SLC] [DevOps Member]169 Posted 22nd October 2021 0 Comments
Hey Divagar.
I think I misread your question. If you are searching for the internal values used to set that specific parameter, this is our mapping:
Up --> 1
Down --> 2
If you want to do a set, it could be that you have to send 1 instead of "Up" and 2 instead of "Down". If you ever come in the situation where a possible option is "Testing", then that will be mapped to 3.
I hope this is the information you are looking for.
With kind regards,
Maxim
