Need a help to find out set / get value on nimbra element
Solved3.17K views18th July 2023
Divagar Vijayarangan [DevOps Member]50 22nd October 2021 0 Comments
Hi Everyone
Need a help to find out set / get value on nimbra element. We are planning to have a visio view for our client when they can enable and disable the services on own.
I can see option to disable and enable the ets on element . But want to find out this value to add in Visio. Any ideas on this ?
Thanks.
Diva
Maxim Bouckaert [SLC] [DevOps Member]179 Posted 22nd October 2021 1 Comment
Hey Divagar,
To add a parameter to a Visio, you will have to use a shape data field.
You'll have to add a field of type element (linking to the element) and a field of type parameter (linking to the parameter you want to show).
A lot of information on Visio can be found in the dataminer help. For example, there is a page "Linking a shape to an element parameter" that gives you a lot of information on this subject (you can find this page by opening the dataminer help and searching for the title).
Maxim Bouckaert [SLC] [DevOps Member] Posted new comment 22nd October 2021
Maxim Bouckaert [SLC] [DevOps Member] commented 22nd October 2021
Just as a small addition, as the info you want to show is in a table. This also works for table parameters by adding “ParameterID:TableRowKey” in the parameter field
