Multiple element instances for the same device
Solved1.07K views9th September 2025
Juan Chavez457 29th April 2025 0 Comments
Does DMS allow the creation of multiple elements for the same device for different functions. Each element will have a different Alarm Template, Correlation Rule? Im not trying it dont want to cause a conflict so figure Id ask the experts 🙂
Juan Chavez Selected answer as best 9th September 2025
Juan Chavez457 Posted 29th April 2025 2 Comments
Thanks @ben.vandenberghe
I will replicate and create alarm template to monitor different parameters along with different correlation rule to send alerts to Slack on different channels.
I had originally attempted to group two alarm templates but that did not work. One alarm template monitored video, Audio , CC and the other monitored SCTE PGM start end on a schedule. I could not get that to work.
Ultimately I create one alarm template and used the Automation Script and scheduler to get that to work but now im losing alerts for the video . I'll try your recommendation on  replicating the element and each will have its own alarm template and correlation rule.
I'll work on this and post any updates
Juan Chavez Posted new comment 30th April 2025
Miguel Obregon [SLC] [DevOps Catalyst] commented 29th April 2025
Hi Juan,
Based on the description of your use case, did you consider using DataMiner services?
Juan Chavez commented 30th April 2025
Hi @miguel.obregon
Yes we use DM Services, I work for Fox (Pico) Los Angeles
