Multiple element instances for the same device
Solved1.07K views9th September 2025
Juan Chavez457 29th April 2025 0 Comments
Does DMS allow the creation of multiple elements for the same device for different functions. Each element will have a different Alarm Template, Correlation Rule? Im not trying it dont want to cause a conflict so figure Id ask the experts 🙂
Juan Chavez Selected answer as best 9th September 2025
Ben Vandenberghe [SLC] [DevOps Advocate]9.73K Posted 29th April 2025 0 Comments
Hi Juan,
You could create two elements that point to the same device, and if the device / its API allows it, it will be polled twice, and you will two times the same device in DataMiner (that you can assign different Alarm Templates and all that),
But more interesting is maybe to use the element replication capability (Replicating elements | DataMiner Docs).  In that case, you will have a second element, which is the exact same as the first element - but the replicated element receives its data from the original element (i.e. the replicated element will not poll the data from the device itself again).  But on the replicated element you can configure a different alarm template, you can create correlation rules on that element, etc. (i.e. the replicated element only takes the parameter values from the original element).
Hope this is what you were looking for.
