Monitor Audio Streams over Multicast TS
Solved771 views28th January 2025
Nur Amirah Abdullah Halim32 22nd October 2024 0 Comments
Can DataMiner be used to monitor audio streams?
If so, how can I monitor audio streams over multicast TS and set up alarms for specific audio quality issues like cracking or hissing sounds?
Thank you.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th January 2025
Felix Wesemeier [DevOps Catalyst]2.39K Posted 22nd October 2024 0 Comments
Hi Nur,
as far as I know the is no DataMiner module to monitor such things directly.
But if you have a mesuring device or software which exposes it‘s results via API, logfiles, SNMP, etc. you can integrate this datasource in to DataMiner.
Best regards,
Felix
