Metric spikes counter
Solved1.64K views19th June 2025alarm alerts metrics
Shaddad Gomid42 19th December 2024 0 Comments
I'm looking for an option that sends an alert in case a specific metric reaches a certain number of spikes beyond the threshold in a certain amount of time.
For example:
CPU usage threshold is 70%, beyond that the severity is critical.
In order not to get flooded with alerts (I'm aware of storm prevention though), I'm looking to configure that an alert will kick-in in case the metric value exceeded the threshold 5 times in 1 minute. I haven't found such option while using the platform.
I would appreciate your assistance,
Shaddad.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 19th June 2025
Leander Druwel [SLC] [DevOps Member]2.10K Posted 20th December 2024 0 Comments
Hi Shaddad,
As Toon mentions, the correlation engine is an excellent option for counting events and triggering or escalating an alarm when the number of occurrences exceeds a predefined threshold.
Then again, for this specific use case of alarming on CPU, we typically apply a hysterises into the alarm template. As you might not necessarily want to alarm when the CPU is just 5 times exceeding a limit, the use case could be that you want to be alerted if the CPU is high for a longer period of time, without any drops. That might indicate a process that is continuously running high.
So, another possibility is to put a hysteresis of e.g. 60 seconds to the CPU parameter. Only if the CPU keeps on running high for a minute or more, the alarm would be generated.
More information can be found on
Configuring hysteresis in an alarm template | DataMiner Docs
