Method of Clearing Alarms from the alarm console using an Automation script
Solved3.39K views27th January 2025alarm monitoring Automation script Automation script solution
A B M Sidddique [DevOps Member]411 16th September 2024 0 Comments
Hello Dojo Community !
I have an use case to build an automation script that would take the input of a period (by date) and then check the system for any warning or minor alarms raised in the system and clear them an automated way. Currently we do this buy right clicking on the alarm and click on the 'clear alarm' option . The Minor and warning alarms we are deleting are ones created internally by the correlation engine so we are not losing important traps just doing some house keeping.
I was investigating and found this : Code example - Take alarm ownership - DataMiner Dojo , and wanted to know if a method for clearing alarms existed (which I couldn't see in the documents site) , if so could you please guide me to it ?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th January 2025
A B M Sidddique [DevOps Member]411 Posted 25th September 2024 4 Comments
These are the alarm properties and the highlighted ones are what I'm wanting to use.
Joachim Ally [SLC] [DevOps Advocate] Posted new comment 23rd July 2025
Joachim Ally [SLC] [DevOps Advocate] commented 3rd October 2024
Hi ABM,
To be honest, I did not really have a good response that I could think of. In the meantime, I saw you did a further follow-up on this question with a new Dojo-question. I really understand this approach and I see that my friendly colleague Tom is helping you further. Just for future reference, I am going to copy-paste the link here: so that if someone else from the community comes across this question, that person can easily get the extra explanation of Tom as well.
https://community.dataminer.services/question/issue-with-automation-script-constructor-argument-error-in-dm-version-10-3-0-0-13184/
I wish you the best of luck and hope you can finally get it working on your DataMiner. 🙂
Kind regards,
Joachim
A B M Sidddique [DevOps Member] commented 3rd October 2024
No worries , Thank you very much for your help on it !
Mohan Ramasamy Veerappan [DevOps Member] commented 22nd July 2025
When I run this script, it says "You don't permission to perform this action." like below,
The following was returned from the script:
EXIT: "Run|Something went wrong: (Code: 0x800402CC) Skyline.DataMiner.Net.Exceptions.DataMinerCOMException: You don't have permission to perform this action.
—> System.Runtime.InteropServices.COMException: Exception from HRESULT: 0x800402CC
Could you please suggest/advice me how to resolve this issue?
Joachim Ally [SLC] [DevOps Advocate] commented 23rd July 2025
Hi Mohan,
In the other question, there is some more explanation on the error you are experiencing. https://community.dataminer.services/question/issue-with-automation-script-constructor-argument-error-in-dm-version-10-3-0-0-13184/ The issue you experience is related to the user rights you have. So when executing this script, you need to be logged in with a user that has the correct permissions (more info here: https://docs.dataminer.services/dataminer/Administrator_guide/Security/DataMiner_user_permissions.html?q=permissions ). Can you please check if the user that you are logged in with has the correct permissions?
If not, please check this FAQ here, it will really help you to get started on changing the permissions (or asking your system administrator to do so): https://docs.dataminer.services/dataminer/Administrator_guide/Security/Basic_security_configuration/Frequently_asked_questions_about_user_group_settings.html .
Kind regards,
Joachim
