Meinberg NMS installation
Solved3.63K views12th July 2023
Kestutis Rokas77 11th November 2022 0 Comments
Hello,
I'm installing NMS system and got stuck at stage where you need to execute "Meinberg_SetupWizard".  After entering all the data wizard is asking I got:
System center logging section revealing some more info:
----------- LogID: 199 -----------
Warning
ServerTime: 2022-11-11 17:31:34
ClientTime: 2022-11-11 17:31:36
Message : Automation script 'Meinberg_SetupWizard' failed to execute (ScriptErrorType: ErrorType) : EXIT: "AS [Meinberg_SetupWizard] Error| Message: Unexpected error:
(Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: Run Subscript 'Meinberg_SetupWizard_Run' Failed: 0x80004005
at Skyline.DataMiner.Automation.Engine.InternalLaunchSubScript(String scriptName, List`1 finalOptions, Int32 inheritSubScript, Dictionary`2& subScriptOutput)
at Skyline.DataMiner.Automation.SubScriptOptions.StartScript()
at Script.RunSafe(Engine engine)
at Script.Run(Engine engine)".
Exception: EXIT: "AS [Meinberg_SetupWizard] Error| Message: Unexpected error:
Data miner version 10.2. Meinberg NMS app version 1.1.0. (tried version 1.1.1 also).
Can I get some help?
Kestutis Rokas77 Posted 14th November 2022 0 Comments
Yes, step by step.
The only step that concerns me is about administrator right. I was given a user type "Administrator":
Is it enough for installation?
Kestutis Rokas Answered question 14th November 2022
You are viewing 1 out of 5 answers, click here to view all answers.
