MediaOps Live – Control Surface giving error
74 views19 hours agoMediaOps MediaOps Live
Teemu Laine34 1 day ago 0 Comments
After a very basic test configuration with MediaOps Live which includes: Enpoints, Levels, VSGs and Categories, the Control Surface is giving me this kind of error:
GQI error: Error in implementation of GetNextPage: Endpoint 9a2473ae-886e-4082-9587-474a77303294 not found for virtual signal group 'MV1 - PIP 3'
What is going wrong?
Joey Vanhalst [SLC] [DevOps Advocate] Answered question 19 hours ago
Joey Vanhalst [SLC] [DevOps Advocate]2.13K Posted 19 hours ago 2 Comments
Hi Teemu, this is likely caused because an endpoint that no longer exists is still used in a virtual signal group. We'll look into handling this better so this doesn't block you from using the Control Surface fully.
Teemu Laine Posted new comment 18 hours ago
Joey Vanhalst [SLC] [DevOps Advocate] commented 19 hours ago
I created a ticket to improve this and also to look into why the VSG app is not loading the virtual signal groups correctly.
Teemu Laine commented 18 hours ago
Thanks!
