Matrix – Changing input/output color
Solved226 views15th January 2026Matrix
Catarina Grilo [SLC] [DevOps Enabler]2.96K 15th January 2026 0 Comments
In a matrix, the color indicating the connected input and output is black.
Would it be possible to change this color to a different one (e.g., blue, red, etc.)?
Catarina Grilo [SLC] [DevOps Enabler] Selected answer as best 15th January 2026
Ive Herreman [SLC] [DevOps Enabler]14.52K Posted 15th January 2026 0 Comments
Hi Catarina,
As far as I know, it’s not possible to change the crosspoint colors directly.
However, you can define different alarm severities for crosspoints, and the UI will display the corresponding color based on the alarm status.
More info can be found here.
