Make Element update in Automation Script
Solved998 views4th February 2025automate Automation DIS Automation script automion script
David Rid [DevOps Enabler]957 4th February 2025 0 Comments
Hello,
I’ve run into an issue with my automation script. I am creating a Haivision Feed with my script. When it is created, a unique ID is assigned to this particular Feed.
When I try to retrieve this ID within the same script, I get the table index, but the new feed index is missing.
After I stop and restart the same script with the same parameters—except that the feed already exists—it has no problem retrieving the ID of the created feed.
Is there a way to tell my script that it needs to reload everything so it can access the newly created Feed ID?
Can you tell my what the issue is?
Thank you for your help.
David Rid [DevOps Enabler] Selected answer as best 4th February 2025
João Severino [SLC] [DevOps Enabler]14.52K Posted 4th February 2025 1 Comment
Hi David,
Could you test if adding the following to the beginning of your script helps you?
engine.SetFlag(RunTimeFlags.NoKeyCaching);
For efficiency reasons, DataMiner will cache the results of your first time fetching certain pieces of data but the call above should allow it to always try and fetch the latest data.
Docs Reference:
  • Method SetFlag | DataMiner Docs
  • Enum RunTimeFlags | DataMiner Docs
David Rid [DevOps Enabler] Posted new comment 6th February 2025
David Rid [DevOps Enabler] commented 6th February 2025
Thank you João!
