Low-Code: Move “Launch a script” cell button to column other than first?
Solved943 views2nd May 2023Dashboard low code app
Robin Becker [DevOps Member]1.42K 2nd May 2023 0 Comments
Is it possible to move the cell button to any other column than the leftmost in a table?
Robin Becker [DevOps Member] Selected answer as best 2nd May 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.48K Posted 2nd May 2023 0 Comments
Hi Robin,
This is currently limited to the first column of the table. Do note that it’s part of our long term vision to have this available on every column.
