Low-Code Grid on-click event
Solved1.75K views24th February 2025grid low-code
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 24th February 2025 0 Comments
In the latest kata an on-click event is used on the grid shapes.
I can't seem to find where to configure this.
I thought it would be in the component settings, but it isn't.
How is this done?
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 24th February 2025
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K Posted 24th February 2025 0 Comments
Nevermind, I found you need to create a shape in the Grid Template Editor and define the On-Click event there
Jeroen Geldhof [SLC] [DevOps Enabler] Answered question 24th February 2025
