Low-code form – DOM – DomInstanceFieldDescriptor
Solved1.84K views13th December 2023DOM form low-code
Leander Druwel [SLC] [DevOps Member]2.10K 12th December 2023 0 Comments
I have a ‘Buildings’ and ‘Regions’ DOM definition, where the Buildings definition has a DomInstanceFieldDescriptor to the Regions definition.
When showing a form on a low-code app to add a new building, the Region field has a drop-down which contains GUIDs i.e. the instances into the Regions definition.
Is there any easy possibility to have another field of that linked instance into the drop-down? Ideally, I’d like to show the Description column into the drop-down.
Thx
Leander Druwel [SLC] [DevOps Member] Selected answer as best 13th December 2023
Ruben Vandepitte [SLC] [DevOps Advocate]2.41K Posted 12th December 2023 1 Comment
In the DOM Definition, you can define which field should be used as ‘Name’ for each instance. The value of that field will then automatically be shown in the dropdown menu.
If no ‘Name’ is specified, by default the guid is displayed.
After updating the Definition, you will likely have to recreate any existing instances for which you want to see this applied.
Leander Druwel [SLC] [DevOps Member] commented 13th December 2023
Thanks Ruben. I had the Name configured, but did not yet recreate the existing instances. After executing that, it works perfectly.
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 12th December 2023 0 Comments
Hi Leander,
I believe your looking for the DomInstanceValueFieldDescriptor (see docs).
However, compared to the DomInstanceFieldDescriptor, this one also references a specific value of that DomInstance
Note that you could also define a name definition (see docs), which provides a meaningful display name for your DOM instance.
Sebastiaan Dumoulein [SLC] [DevOps Enabler] Edited answer 12th December 2023
