Low code apps – Buggy display of drop down with a mix of static and dynamic values
Solved1.55K views26th March 2024Dropdown feed LCA LowCode lowcodeapps
Jon Corral [SLC] [DevOps Member]464 26th March 2024 0 Comments
I am using a drop down to try to emulate that of Cube which shows you not only the list of available alarm/trend templates but also the option of no monitoring .
For some reason the no monitoring option seems to be hidden by the drop down UI. Anyhow, I can select it so I can see that the insertion I have made to the list is working properly.
With this in view, have I found a buggy behavior here or am I doing something wrong?
Jon Corral [SLC] [DevOps Member] Selected answer as best 26th March 2024
Gilles Bara [SLC] [DevOps Advocate]7.23K Posted 26th March 2024 2 Comments
The dropdown will see these options as html tags and will try to display it accordingly (a safe sanitized html string). In this case this would result into an empty tag without any content, hence the white gaps. As the dropdown its html feature is mainly used for internal style enhancements (eg highlighting the parts that match a filter), this can be considered a bug. A workaround would be to avoid usage of < and >, or add spaces in between them (< No Monitoring >).
Gilles Bara [SLC] [DevOps Advocate] Posted new comment 26th March 2024
Jon Corral [SLC] [DevOps Member] commented 26th March 2024
Hello Gilles,
That worked, thank you. Considering this might be a bug, I am wondering to which mail could I mail the bug to.
Thanks for your help!
Gilles Bara [SLC] [DevOps Advocate] commented 26th March 2024
You can send it to the support mailbox of the data-exploration domain.
