Low Code Apps; Automation Scripts with Variables; Options in how to model the parameterdata?
Solved1.98K views6th July 2023low code apps
8
Jan Piet Ballegeer [DevOps Advocate]344 5th April 2023 0 Comments
Hi; Let me jump in the immediate use case here.
I have a list of channels to select from in low code apps; I have a feed which shows me the multicast
feedA: 239.1.1.11:1234
The expected parameter input is: udp://239.1.1.11:1234
how do I combine a set string with a feed in the low code apps option?
I was hoping to do something as "userdefinableText"+"FeedValue"
but I do not seem to be able to combine items; or is there another option somehwere?
Use case: select stb; press the "select TV channel" button
select channel and press Retune STB.
Wouter Bogaert [SLC] [DevOps Enabler]1.28K Posted 6th April 2023 0 Comments
Hi Jan Piet,
As far as I'm aware you cannot prepend or append anything to a parameter when selecting a feed.
I would suggest to add an additional parameter and combine both of them in your automation script.
Wouter Bogaert [SLC] [DevOps Enabler] Answered question 6th April 2023
