Low Code App : Simultaneous connection limit?
Solved1.81K views17th January 2024low code app low code apps
Yvan Barbotin [DevOps Member]50 16th January 2024 0 Comments
Hi community,
Is there a limit to the number of simultaneous connections to low code apps?
On existing system, when we connect with several users to 1 or multiple low code apps on a same DMA, we see that the total processor load and physical memory usage are increasing.
Thanks
Sebastiaan Dumoulein [SLC] [DevOps Enabler] Answered question 17th January 2024
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 17th January 2024 0 Comments
Hi Yvan,
As far as I know there is no connection limit to Low-Code Apps. It's normal that with an increased user activity you will see more resource utilization on the backend.
The impact on the backend depends on factors such as the amount of information displayed, real-time updates, and user activity. The increase on the backend should be limited per user, if this is not the case your solution will not scale and corrective actions will be required.
