Low-code app – how to show aggregation rule info in gauge control
Solved1.27K views3rd June 2024aggregation low-code
Leander Druwel [SLC] [DevOps Member]2.10K 3rd June 2024 0 Comments
Hi all,
I have configured an aggregation rule on views to sum the energy consumption of multiple sensors in real-time, and have alarming and trending enabled.
In low-code apps, I'd like to display a gauge control showing the aggregated energy consumption for a specific selected site. Although I'm able to retrieve the aggregated data through a GQI, the gauge control seems to only allow a parameter selection. However, the aggregated element is not a visible one, so not selectable.
Are there any ways to display a value from an aggregation rule into a gauge control of a low-code app?
Thx
Leander Druwel [SLC] [DevOps Member] Selected answer as best 3rd June 2024
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.50K Posted 3rd June 2024 1 Comment
Hi Leander,
Aggregation parameters apply on one or more views. You can find them under the Parameters data section (and by selecting your desired view):
From there onwards you can use them like regular parameters.
Leander Druwel [SLC] [DevOps Member] Posted new comment 3rd June 2024
Leander Druwel [SLC] [DevOps Member] commented 3rd June 2024
Perfect, makes full sense. Thanks!
