Low Code App : execution of interactive automation script fails
Solved2.01K views9th January 2023interactive automation script low code app
Emmanuel Dal [SLC] [DevOps Member]4.65K 9th January 2023 0 Comments
Each time I try to execute an Interactive Automation Script from a Low Code App, I get following error message:
Am I missing a configuration step ?
Emmanuel Dal [SLC] [DevOps Member] Selected answer as best 9th January 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 9th January 2023 1 Comment
Hi Emmanuel,
Interactive Automation Scripts in our web applications require web socket communication in order to achieve a good user experience. If web sockets are not available (for whatever reason), then the 'Failed to connect to WebSocket' error message is shown.
For more information on how to enable web sockets, see this question.
Emmanuel Dal [SLC] [DevOps Member] commented 9th January 2023
Thank you Sebastiaan; it now works well!
