Lock Alarm Console in Cube
Solved3.76K views8th March 2021Alarm Console Dashboards NOC SLAlerter
Jonathan Triboulet [SLC]10 3rd March 2021 0 Comments
In a NOC application, I have a requirement to 'not be allowed to miss an alarm' , meaning that anyone must see the alarm console at all times.
Is it possible to make sure that the Alarm console cannot be hidden in Cube (eg. disable the show/hide button?)
If not, I had the following workarounds in mind :
  • use a dedicated dashboard
  • use the alerter to display the list of alarms at all times + notifications / sounds
Jonathan Triboulet [SLC] Selected answer as best 8th March 2021
Ben Vandenberghe [SLC] [DevOps Advocate]9.73K Posted 3rd March 2021 2 Comments
Not sure if this would help Jonathan, but it kind of reminded me about a user who used the 'clearable' alarms.  Under normal circumstances, when the alarm condition is no longer valid, an alarm clears and disappears from the Active Alarm list.  With the clearable option, the alarm would go into a clearable state (and stay visible in the active alarm list, showing green to indicate that the situation no longer applies), and the operator has to manually clear the alarm (change it from clearable to cleared).  This is an option used by operations that want to make sure that nobody can ever say that they did not see an alarm, because it has to be manually cleared by somebody.  Not sure if this would be of interest for your case.
Locking the Alarm Console so that it cannot be hidden is not available.  Then again, is that a guarantee that somebody will see an alarm?  Would the banner notification option maybe also be of interest?  So that a new alarm is always visibly announced in the header op Cube, even when the Alarm Console is minimized?
Jonathan Triboulet [SLC] commented 5th March 2021
This is a great mechanism, and would probably serve the purpose right !
Jonathan Triboulet [SLC] commented 8th March 2021
I select this one as an answer because it provides a solid and elegant workaround, however the other answers very valid UI configuration options as well.
