Lock Alarm Console in Cube
Solved4.39K views8th March 2021Alarm Console Dashboards NOC SLAlerter
Jonathan Triboulet [SLC]10 3rd March 2021 0 Comments
In a NOC application, I have a requirement to 'not be allowed to miss an alarm' , meaning that anyone must see the alarm console at all times.
Is it possible to make sure that the Alarm console cannot be hidden in Cube (eg. disable the show/hide button?)
If not, I had the following workarounds in mind :
  • use a dedicated dashboard
  • use the alerter to display the list of alarms at all times + notifications / sounds
Jonathan Triboulet [SLC] Selected answer as best 8th March 2021
Miguel Obregon [SLC] [DevOps Catalyst]23.76K Posted 3rd March 2021 2 Comments
Hi Jonathan,
A possible option is to dock the alarm tab to the workspace:
This will link to display the alarm tab in the card pane:
Pieter Van Compernolle [SLC] [DevOps Enabler] Posted new comment 4th March 2021
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 4th March 2021
On top of that, you can also ‘pin’ the alarm card in your workspace. This will ensure that the alarm card will not get closed or replaced by another card.
You can also add it to a saved workspace that can be linked to specific groups of users
You can find the ‘pin’ action in the ‘hamburger’ menu on the card.
