Lock Alarm Console in Cube
Solved4.78K views8th March 2021Alarm Console Dashboards NOC SLAlerter
Jonathan Triboulet [SLC]10 3rd March 2021 0 Comments
In a NOC application, I have a requirement to 'not be allowed to miss an alarm' , meaning that anyone must see the alarm console at all times.
Is it possible to make sure that the Alarm console cannot be hidden in Cube (eg. disable the show/hide button?)
If not, I had the following workarounds in mind :
  • use a dedicated dashboard
  • use the alerter to display the list of alarms at all times + notifications / sounds
Jonathan Triboulet [SLC] Selected answer as best 8th March 2021
Michaël Pincket [SLC] [DevOps Advocate]2.13K Posted 3rd March 2021 1 Comment
Hi Jonathan,
If you don't want to miss an alarm you should have a look at the "Audible Alert" option in the hamburger menu of the alarmconsole. With this option you can let the alarmconsole play a sound for an incomming alarm. This sound will be played when the alarm is a new one or when the severity of an existing alarm increases.  This option can be configured for each tabpage seperately.
Jonathan Triboulet [SLC] Posted new comment 4th March 2021
Jonathan Triboulet [SLC] commented 4th March 2021
Nice ! And this is enhanced in the SLAlerter with custom audio for each type / group of alarms.
