Load/run package from automation script
Solved2.20K views9th November 2021Automation upgrade package
Stijn Declerck [SLC] [DevOps Advocate]824 28th October 2021 0 Comments
Hi all,
I'd like to load/run multiple .dmapp files from an automation script to import functions (SRM). The method below launches the installer, but you still have to click "Upgrade" manually.
foreach (FileInfo file in newFiles)
engine.RunClientProgram(file.FullName, true);
Is it possible to do this somehow automatically?
Stijn Declerck [SLC] [DevOps Advocate] Selected answer as best 9th November 2021
Miguel Obregon [SLC] [DevOps Catalyst]23.68K Posted 28th October 2021 0 Comments
Hi Stijn,
In order to install multiple .dmapp packages, you can use the Taskbar Utility using command line options (DataMiner Help). I tried with a batch script and I was able to install multiple .dmapp packages, however I didn't try running it from an automation script.
Miguel Obregon [SLC] [DevOps Catalyst] Edited answer 28th October 2021
