Linking DCF interfaces with matrix input/output id’s
Solved2.92K views27th September 2023DCF DCF connection DCF Connections Matrix
hans sanders [DevOps Advocate]618 1st August 2023 0 Comments
When using DCF on a matrix element there seems to be no 'straight forward' way to determine what DCF interface corresponds with what matrix in or output nbr.
To execute a crosspoint set one has to specify the matrix in and output numbers.
But when resolving interfaces through DCF the only way I could determine the matching in/output id of the matrix command is to go through the labels assigned (but these are not mandatory and not guaranteed unique neither).
Is there any unambiguous way to link DCF interfaces to matrix i/o numbers ?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th September 2023
João Severino [SLC] [DevOps Enabler]14.78K Posted 15th September 2023 3 Comments
One small addition to what Tim answered, for DCFs linked directly to a matrix and not to a table-backed data source the format of the content in the [Interface Dynamic Link] parameter (id 65095) is slightly different.
Below you can see an example
Here you can see that the string has 3 "components".
For inputs, the second item corresponds to the matrix input numbering, and for outputs, the second item has a * and the numbering is on the 3 component.
As you may have noticed in the screenshot above, the numbering for the outputs does not start at 1 but at 3, this is because output numbering starts where the inputs stop.
So, if you have a 2*10 matrix, output numbering will start at 3 like you see here, however, if you were to have a 64*64 matrix the first output would be number 65.
João Severino [SLC] [DevOps Enabler] commented 15th September 2023
Just for completeness of information, the first component in that parameter links to the id of the ParameterGroup associated with the matrix (see https://docs.dataminer.services/develop/schemadoc/Protocol/Protocol.ParameterGroups.html and https://docs.dataminer.services/develop/schemadoc/Protocol/Protocol.ParameterGroups.Group-id.html)
So if you were to have multiple matrixes you could use that to differentiate between Input 1 of one matrix and Input 1 of another.
hans sanders [DevOps Advocate] commented 18th September 2023
For sure a very helpfull answer but the calculation of output Id remains a little dodgy to me.
For instance on my 20×18 ‘pro-bel SW P08’ matrix the output seems to apply on offset of ‘4002’… (first output showing up as 1;*,4003).
So scriping the offset does not seem to be so straightforward. The element reports number if inputs: 20 – number of outputs: 18 so I had assumed taking an offset of 18 to be taken into account.
João Severino [SLC] [DevOps Enabler] commented 18th September 2023
The offset of 4002 should be due to the maximum size that the particular matrix supports.
Very often the same connector supports different devices or the device itself supports a variable size of inputs/outputs so we create the connector to be compatible with a more general scenario.
I would guess the matrix is defined to be something like 4002×4002 or something similar and that in code it is being resized so you only see the important inputs/outputs/crosspoints and hence having the 20×18 but in the background all inputs will remain.
