LCAs Node Edge – Changing the color of a masked node
Solved1.40K views19th September 2024node-edge
Maria Cunha [SLC] [DevOps Advocate]433 1st July 2024 0 Comments
Hello Dojo community,
I am working on a node edge component, and I want the coloring mode to be "Alarm" but when my alarm is masked the color of the node is by default the color of the background, so I am not able to se the corresponding node.
Is it possible to change the icon color when the alarm related to that node is masked?
Maria Cunha [SLC] [DevOps Advocate] Selected answer as best 19th September 2024
Ward Haeck [SLC] [DevOps Advocate]3.55K Posted 2nd July 2024 0 Comments
Hi Maria,
Through node overrides you can change the icon/color based on a condition.
In your case you will probably want to change the appearance based on the alarm being masked or not. For that you will have to add that information to the data of the nodes. In order to be able to use it within the condition.
What datasource/query are you using to populate the nodes?
More info about node overrides and node edge:
  • https://docs.dataminer.services/user-guide/Advanced_Modules/Dashboards_and_Low_Code_Apps/Low_Code_Apps/Tutorials/Tutorial_Apps_Node_Edge.html
  • https://docs.dataminer.services/user-guide/Advanced_Modules/Dashboards_and_Low_Code_Apps/Visualizations/Available_visualizations/Other/Node_edge_graph.html
Best regards, Ward
