LCA sort by “ascending” order
Solved1.38K views28th August 2025
Juan Chavez514 18th December 2024 3 Comments
Im trying to sort Ethernet Port name by asccending order however, Ive tried several operators Sort by, Then sort by however cannot get expected result. I end up with Sort ascending order but all 1's for example 1,10,11,12,13,.... then all 2's 2,20,21,22,23
has anyone seen this and what I need to do to resolve?
Thanks
Juan Chavez Posted new comment 28th August 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 19th June 2025
Hi Juan,
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th August 2025
Juan Chavez commented 28th August 2025
Can be closed TY
Matthijs Favorel [SLC] [DevOps Advocate]2.63K Posted 18th December 2024 1 Comment
Hi Juan,
This 'natural' sorting seems easy for us, but it's not that easy for a DB to do this (note that most of the sorting is happening on the DB for performance reasons).
There is however a way to achieve what you are after, although it requires some extra work in an ad-hoc data source, see this guide.
Juan Chavez Selected answer as best 28th August 2025
Juan Chavez commented 18th December 2024
Thank you @Matthis.Favorel for the detailed information, I will get with one of our developers to create GQI for this. Will update thread when's we are able to sort numerically in ascending order
