LCA – Conditional case for empty value
Solved490 views29th September 2025
Stefan Fransson [DevOps Advocate]221 26th September 2025 0 Comments
I have a table component in my LCA with a column that can have any value OR be empty. And I'm trying to set a Conditional case to show an icon when the value is empty.
Is there a way to set the filter value to empty or null or something similar, to only show the icon when the field is empty?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 29th September 2025
Pieter Van Compernolle [SLC] [DevOps Enabler]3.80K Posted 26th September 2025 2 Comments
Hi Stefan,
Typically I do that via the regex comparison ^$
Does that work for you?
Best Regards
Stefan Fransson [DevOps Advocate] commented 26th September 2025
Hi Pieter, ok, I will see if I can make it work. Thank you!
It worked, thanks again.
