Kata 62 – could not load assembly
Solved1.30K views1st April 2025Kata Performance Analyzer
Felix Wesemeier [DevOps Catalyst]2.39K 28th March 2025 0 Comments
Hi Community,
I tried to finish the Kata #62 PerformaceAnalyzer.
I get an error inside the LCA:
Error trapped: Error thrown in implementation of OnPrepareFetch: Could not load file or assembly 'Skyline.DataMiner.Utils.PerformanceAnalyzer, Version=3.0.2.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
But I found the file in the correct location on the server as defined in the script: C:\Skyline DataMiner\ProtocolScripts\DllImport\skyline.dataminer.utils.performanceanalyzer\3.0.2\lib\net48\Skyline.DataMiner.Utils.PerformanceAnalyzer.dll
Why do I get this error message?
Felix Wesemeier [DevOps Catalyst] Selected answer as best 1st April 2025
Edib Šupić [SLC] [DevOps Enabler]2.55K Posted 1st April 2025 2 Comments
Hi Felix,
The issue happens, as João mentioned, because you are not using GQI DxM. I've encountered similar issue with being unable to enable GQI DxM, but I thought it was a lone case, I will bring it up internally.
Regarding where you found the DLL that is not the correct location for GQI, in order for GQI to be able to access DLL it needs to be in C:\Skyline DataMiner\Files folder. This is true for any GQI that uses NuGets.
Can you try copying the DLL to that folder and see if that resolves your issue?
Let me know if you need any further help,
Cheers
Edib Šupić [SLC] [DevOps Enabler] Posted new comment 1st April 2025
Felix Wesemeier [DevOps Catalyst] commented 1st April 2025
Hi Edib,
placing the file manually into C:Skyline DataMinerFiles does work.
Thank you!
Any way to put it into the correct folder when publishing the Nugets from Visual Studio to the DMA?
Edib Šupić [SLC] [DevOps Enabler] commented 1st April 2025
Hi Felix,
Glad I could help.
I don't think so, this is a GQI limitation, more precisely the SLHelper limitation. I think one of the goals the GQI DxM tries to address is this one.
