Issues fill table on custom protocol
Solved658 views24th May 2025#cprotocol driver load protocol failed protocol.clear
Jose Araujo [DevOps Advocate]1.01K 24th May 2025 0 Comments
Hi, I have issues when try to fill my table in my custom protocol
Table code
<Paramid="1101">
<Name>ServiceTableUUID</Name>
<Description>UUID</Description>
<Type>read</Type>
<Interprete>
<RawType>other</RawType>
<Type>string</Type>
</Interprete>
<Display>
<RTDisplay>true</RTDisplay>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1102">
<Name>ServiceTableService</Name>
<Description>Service Name</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1103">
<Name>ServiceTableStateService</Name>
<Description>Service Status</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1104">
<Name>ServiceTablechunk</Name>
<Description>Chunk</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1100"trending="true">
<Name>ServiceTable</Name>
<Description>Table Of Services</Description>
<Type>array</Type>
<ArrayOptionsindex="0">
<ColumnOptionidx="0"pid="1101"type="retrieved"options=";save" />
<ColumnOptionidx="1"pid="1102"type="retrieved"options=";save" />
<ColumnOptionidx="2"pid="1103"type="retrieved"options=";save" />
<ColumnOptionidx="3"pid="1104"type="retrieved"options=";save" />
</ArrayOptions>
<Information>
<Subtext>
<![CDATA[Table Of Services]]>
</Subtext>
</Information>
<Display>
<Positions>
<Position>
<Page>Services</Page>
<Column>0</Column>
<Row>0</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Typeoptions="tab=columns:1101|0-1102|1-1103|2-1104|3,width:350-220-112-100,sort:STRING-STRING-STRING-STRING,lines:10,filter:true">table</Type>
</Measurement>
</Param>
QAction code
using System;
using Skyline.DataMiner.Scripting;
public class Script
    public void Run(SLProtocol protocol)
        try
            object[][] table = new object[][]
                new object[] { Guid.NewGuid().ToString(), "Servicio A", "Activo", "true" },
                new object[] { Guid.NewGuid().ToString(), "Servicio B", "Inactivo", "false" },
            protocol.SetParameter(1100, table);
            protocol.Log("Table load", LogType.Information);
        catch (Exception ex)
            protocol.Log("ERROR loading table " + ex.Message, LogType.Error);
Log error
2025/05/24 06:02:38.964|SLManagedScripting.exe|ManagedInterop|ERR|-1|14|ERROR loading table Specified array was not of the expected type.
2025/05/24 06:02:38.964|SLProtocol - 15024 - sdfsdfs|17308|CParameter::RunQActions|DBG|5|QAction 106 finished
2025/05/24 06:02:39.141|SLProtocol - 15024 - sdfsdfs|17308|CGroup::Execute|DBG|6|Finished executing group 50
2025/05/24 06:02:39.142|SLProtocol - 15024 - sdfsdfs|1892|CTimer::TimerThreadFunc|DBG|6|Last group finished.
Jose Araujo [DevOps Advocate] Selected answer as best 24th May 2025
Miguel Obregon [SLC] [DevOps Catalyst]22.20K Posted 24th May 2025 1 Comment
Hi Jose,
I believe that the method that you are using to the update the content of the table is not correct.
Can you try using the method FillArrayWithColumn?
Hope it helps.
Jose Araujo [DevOps Advocate] commented 24th May 2025
Hi Miguel,
Its working using FillArrayWithColumn, thanks for you help!
