Issue with the method : engine.SendEmail()
Solved1.46K views11th July 20230x80004005 engine.SendEmail()
Hugo REHBEN213 21st November 2022 0 Comments
Good evening Skyline team,
I have created a small script retrieving different parameters from different equipment.
In this script I am using the method called engine.SendEmail.
When I am executing this script from the automation : everything is working except the mail notification.
When I am executing this script from the scheduler : everything is working including the mail notification.
In the information events the error is the following : "Email/SMS Failed: 0x80004005 (Script 'Bein TEST FOR TS500')".
Could you explain please ?
Thanks by advance !
Hugo REHBEN213 Posted 21st November 2022 0 Comments
I have found the issue, we recently move to 10.2 which introduce new permissions and one of those permissions is regarding the send of email via DataMiner System which was not ticked in my case.
Apologies for inconveniences.
You can delete this thread if you want.
