Issue with Script Output
Solved2.09K views7th August 2024AddScriptOutput lowcodeapps
Ross Elliott [DevOps Advocate]1.20K 6th August 2024 0 Comments
Hi, I can't seem to get a script output into my Low Code app. I'm following dynamically inject the output of the script. and looking at previous answer Feed Output text from Automation Script to Text Input - DataMiner Dojo but I can't get it to work. It's working fine when triggering from Visio in Cube.
I have the following in my script
In my app Button 1 triggers the script from within page scriptOutput but the HTML box in the app isn't recognising the HTML code.
Ross Elliott [DevOps Advocate] Selected answer as best 7th August 2024
Wout Mahieu [SLC] [DevOps Catalyst]12.34K Posted 6th August 2024 2 Comments
Hi Ross,
Looking at the screenshot you provided of the LCA, I notice that there is no highlighting in the HTML input and that the Web component shows the feed link as plaintext. Could it be that you are running a DataMiner version < 10.3.0 [CU14]/10.4.0 [CU2]/10.4.5? The feed linking feature is not available in older versions of DataMiner. You can check this by clicking your user icon > about > web version.
Ross Elliott [DevOps Advocate] commented 6th August 2024
Hi, yes I should have added we’re on 10.3.12 (CU0)
Wout Mahieu [SLC] [DevOps Catalyst] commented 6th August 2024
Hi Ross, 10.3.12[CU0] does not include this feature. It is available from the versions mentioned in my answer (10.3.12[CU0] is older than 10.3.0[CU14])
