Issue with Parameter Not Read Correctly on First Execution
Solved630 views4th July 2025Protocol Deployment Issue QActions
Jose Araujo [DevOps Advocate]1.01K 4th July 2025 0 Comments
I’m encountering an issue with two QActions involved in a flow that updates a parameter via a PUT request to an external API.
I have two QActions:
QA20: Prepares the API URL and sets the new name parameter.
QA21: Modifies a JSON payload with the new name and sends it via PUT.
The flow works, but only on the second attempt. What’s more confusing is:
The parameter (newnameservice) is correctly set and visible in the protocol logs during QA21. When run QA20 newnameservice in log appear newnameservice = ""
QA21 runs right after the HTTP GET session completes, but fails to pick up the value on the first attempt.
On the second attempt, it always uses the value that was originally set during the first one (as if it had been delayed).
I implemented a while loop in QA21 to retry reading the newnameservice and customurlservicesresponse parameters up to 100 times with a 100ms delay.
However, even with this retry logic, the values still come up as null or empty on the first execution.
On the second execution, it suddenly works — but with the previous value, not the one just set.
QA20:
using System;
using Skyline.DataMiner.Scripting;
public class QAction
public void Run(SLProtocol protocol)
try
string rowKey = protocol.RowKey();
string ip = protocol.GetParameter(Parameter.nmosipaddress) as string;
string newName = protocol.GetParameter(1902) as string;
if (string.IsNullOrWhiteSpace(rowKey) || string.IsNullOrWhiteSpace(ip))
return;
string getUrl = $"http://{ip}/api/v1/servicesmngt/services/{rowKey}";
protocol.SetParameter(Parameter.customurlservices, getUrl);
protocol.SetParameter(Parameter.newnameservice, newName);
//protocol.CheckTrigger(4);
catch (Exception ex)
protocol.Log("Error en QA_GET: " + ex.Message, LogType.Error);
QA21:
using Newtonsoft.Json;
using Newtonsoft.Json.Linq;
using System;
using System.Threading;
try
string newName = null;
string jsonOriginal = null;
int tries = 0;
int maxTries = 100;
while (tries < maxTries)
newName = protocol.GetParameter(Parameter.newnameservice) as string;
jsonOriginal = protocol.GetParameter(Parameter.customurlservicesresponse) as string;
if (!string.IsNullOrWhiteSpace(newName) && !string.IsNullOrWhiteSpace(jsonOriginal))
break;
Thread.Sleep(100);
tries++;
if (string.IsNullOrWhiteSpace(newName) || string.IsNullOrWhiteSpace(jsonOriginal))
return;
JObject servicioJson = JObject.Parse(jsonOriginal);
if (servicioJson["Name"] == null)
return;
servicioJson["Name"] = newName;
string jsonActualizado = JsonConvert.SerializeObject(servicioJson, Formatting.None);
protocol.SetParameter(Parameter.updateservice, jsonActualizado);
// protocol.CheckTrigger(5);
protocol.Log("Error en QA_PUT: " + ex.Message, LogType.Error);
<?xml version="1.0" encoding="utf-8" ?>
<Protocol xmlns="http://www.skyline.be/protocol">
<Name>test</Name>
<Description>Test</Description>
<Version>1.0.0.1</Version>
<IntegrationID>DMS-DRV-0001</IntegrationID>
<Provider>Test</Provider>
<Vendor>Test</Vendor>
<VendorOID>1.3.6.1.4.1.8813.2.99</VendorOID>
<DeviceOID>100</DeviceOID>
<ElementType>Monitoring Platform</ElementType>
<Type relativeTimers="true">http</Type>
<Display defaultPage="General" pageOrder="General;----------;Security;----------;Resources;Management;Networking;Services;Test Values;----------;Alarms;----------;Webpage#http://[Polling Ip]/" wideColumnPages="Test Values;Security;Alarms;Module;Sensor;Services"/>
<SNMP includepages="true">auto</SNMP>
<Compliancies>
<CassandraReady>true</CassandraReady>
<MinimumRequiredVersion>10.4.0.0 - 12752</MinimumRequiredVersion>
</Compliancies>
<Params>
<Param id="1">
<Name>AfterStartup</Name>
<Description>After Startup</Description>
<Type>dummy</Type>
</Param>
<Param id="2">
<Name>StatusCodePingCheck</Name>
<Description>Statuscodepingcheck</Description>
<Type>read</Type>
<Interprete>
<RawType>other</RawType>
<Type>string</Type>
</Interprete>
</Param>
<Param id="3">
<Name>PingCheckResponse</Name>
<Description>Pingcheckresponse</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
</Param>
<Param id="4">
<Name>StatusCodeLogin</Name>
<Description>Statuscodelogin</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
</Param>
<Param id="5">
<Name>LoginResponse</Name>
<Description>Login Response</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
</Param>
<Param id="6">
<Name>LoginSend</Name>
<Description>Login Send</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
</Param>
<Param id="7" trending="false">
<Name>StatusFirmware</Name>
<Description>Status Firmware</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<RTDisplay>false</RTDisplay>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="8" trending="false">
<Name>FirmwareResponse</Name>
<Description>Response of Firmware API</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="9" trending="false">
<Name>TimeZone_Value</Name>
<Description>Preset Combobox Values</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
<DefaultValue>America/New York;America/Los Angeles;America/Bogota;America/Mexico City;America/Buenos Aires;Europe/London;Europe/Madrid;Europe/Berlin;Europe/Paris;Asia/Tokyo;Asia/Shanghai;Asia/Dubai;Asia/Kolkata;Australia/Sydney;Africa/Johannesburg</DefaultValue>
</Interprete>
<Display>
<RTDisplay>true</RTDisplay>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="10" trending="false">
<Name>StatusResources</Name>
<Description>Status Resource</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="11" trending="false">
<Name>ResourcesResponse</Name>
<Description>Response of Resources API</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="12" trending="false">
<Name>StatusMemory</Name>
<Description>Status Memory</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="13" trending="false">
<Name>MemoryResponse</Name>
<Description>Respondse of Memory API</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="14" trending="false">
<Name>StatusCPU</Name>
<Description>Status CPU</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="15" trending="false">
<Name>CPUResponse</Name>
<Description>Respondse of CPU API</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="16" trending="false">
<Name>StatusModule</Name>
<Description>Status Module</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="17" trending="false">
<Name>ModuleResponse</Name>
<Description>Respondse of Module API</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="18" trending="false">
<Name>StatusAlarms</Name>
<Description>Status Alarms</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="19" trending="false">
<Name>AlarmsResponse</Name>
<Description>Respondse of Alarms API</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="20" trending="false">
<Name>StatusDeleteAlarms</Name>
<Description>Status Delete Alarms</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="21" trending="false">
<Name>DeleteAlarmsResponse</Name>
<Description>Respondse of Delete Alarms API</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="22" trending="false">
<Name>StatusMAC</Name>
<Description>Status MAC</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="23" trending="false">
<Name>MACResponse</Name>
<Description>Respondse of MAC</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="24" trending="false">
<Name>StatusFingerprint</Name>
<Description>Status Fingerprint</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="25" trending="false">
<Name>FingerprintResponse</Name>
<Description>Respondse of Fingerprint</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="26" trending="false">
<Name>StatusNMOS</Name>
<Description>Status NMOS</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="27" trending="false">
<Name>NMOSResponse</Name>
<Description>Respondse of NMOS</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="28" trending="false">
<Name>StatusDate</Name>
<Description>Status DAte</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="29" trending="false">
<Name>DateResponse</Name>
<Description>Respondse of Date</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="30" trending="false">
<Name>StatusSNMP</Name>
<Description>Status SNMP</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="31" trending="false">
<Name>SNMPResponse</Name>
<Description>Respondse of SNMP</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="32" trending="false">
<Name>StatusSyslog</Name>
<Description>Status Syslog</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="33" trending="false">
<Name>SyslogResponse</Name>
<Description>Respondse of Syslog</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="34" trending="false">
<Name>StatusMNGTSERV</Name>
<Description>Status Management Services</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="35" trending="false">
<Name>SERVMNGTResponse</Name>
<Description>Respondse of Management Services</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="36" trending="false">
<Name>StatusNet1</Name>
<Description>Status Network Monitor</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="37" trending="false">
<Name>Net1Response</Name>
<Description>Respondse of  Network Monitor</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="38" trending="false">
<Name>StatusServices</Name>
<Description>Status Service</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="39" trending="false">
<Name>ServicesResponse</Name>
<Description>Response of Services</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="40" trending="false">
<Name>CustomURLServices</Name>
<Description>Respondse of Services</Description>
<Type>read</Type>
<Information>
<Subtext>.</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Page>Test Values</Page>
<Column>0</Column>
<Row>0</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="41" trending="false">
<Name>StatusCustomURLServices</Name>
<Description>Custom Services Status</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>2</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="42" trending="false">
<Name>CustomURLServicesResponse</Name>
<Description>Response of Custom Services</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>1</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="43" trending="false">
<Name>UpdateService</Name>
<Description>Custom Service Update</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>3</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="44" trending="false">
<Name>StatusUpdateService</Name>
<Description>Status of Custom Service Updates</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>4</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="45" trending="false">
<Name>ResponseUpdateService</Name>
<Description>Response of Custom Service Updates</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>5</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="46" trending="false">
<Name>NewNameService</Name>
<Description>New Name Service Name</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>6</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="100" trending="true">
<Name>APIHealth</Name>
<Description>API Health</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[API Health Status]]>
</Subtext>
</Information>
<Interprete>
<RawType>numeric text</RawType>
<Type>double</Type>
</Interprete>
<Alarm>
<Monitored>true</Monitored>
<CH>Fail</CH>
<Normal>Healhty</Normal>
</Alarm>
<Display>
<Positions>
<Position>
<Page>General</Page>
<Column>0</Column>
<Row>1</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>discreet</Type>
<Discreets>
<Discreet>
<Display>Fail</Display>
<Value>0</Value>
</Discreet>
<Discreet>
<Display>Healhty</Display>
<Value>1</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="101" trending="false">
<Name>ProtocolSupport</Name>
<Description>Protocol Support</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[API support with this protocol]]>
</Subtext>
</Information>
<Alarm>
<Normal>Support</Normal>
<CH>Not Support</CH>
</Alarm>
<Interprete>
<Type>double</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>8</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Discreets>
<Discreet>
<Display>Not Support</Display>
<Value>0</Value>
</Discreet>
<Discreet>
<Display>Support</Display>
<Value>1</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="102" trending="false">
<Name>APIVersion</Name>
<Description>API Version</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[API Version]]>
</Subtext>
</Information>
<Alarm>
<Normal>2.4.0.3</Normal>
<CH>=!2.4.0.3</CH>
</Alarm>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>2</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="103" trending="false">
<Name>FirmwareVersion</Name>
<Description>Firmware Version</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[Firmware Version]]>
</Subtext>
</Information>
<Alarm>
<Normal>4.1.30.0-0</Normal>
<CH>=!4.1.30.0-0</CH>
</Alarm>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>3</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="104" trending="false">
<Name>ServerUUID</Name>
<Description>UUID</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[Unique UUID of Encoder]]>
</Subtext>
</Information>
<Alarm>
<Monitored>false</Monitored>
</Alarm>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>4</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="105" trending="false">
<Name>EncoderStatus</Name>
<Description>Encoder Status</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[Login Status of Encoder]]>
</Subtext>
</Information>
<Alarm>
<Normal>Authorized</Normal>
<CH>Not Authorized</CH>
</Alarm>
<Interprete>
<Type>double</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Page>Security</Page>
<Column>1</Column>
<Row>1</Row>
</Position>
<Position>
<Column>0</Column>
<Row>5</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Discreets>
<Discreet>
<Display>Not Authorized</Display>
<Value>0</Value>
</Discreet>
<Discreet>
<Display>Authorized</Display>
<Value>1</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="106" trending="false">
<Name>FirmwareRelease</Name>
<Description>Firmware Release</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[Firmware release version]]>
</Subtext>
</Information>
<Alarm>
</Alarm>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>6</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="107" trending="false">
<Name>ServerType</Name>
<Description>Encoder Version</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>7</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="108" trending="false">
<Name>VersionType</Name>
<Description>Version Release</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<Normal>official</Normal>
<CH>unofficial</CH>
</Alarm>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>8</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="109" trending="false">
<Name>Virtualization</Name>
<Description>Virtualization</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Page>Resources</Page>
<Column>1</Column>
<Row>5</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="110" trending="false">
<Name>ServerName</Name>
<Description>Server Name</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>1</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="210" setter="true">
<Type>write</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>1</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="112" trending="false">
<Name>MACAddress</Name>
<Description>MAC Address</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Page>License</Page>
<Column>0</Column>
<Row>1</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="113" trending="false">
<Name>Fingerprint</Name>
<Description>Fingerprint</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>2</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="114" trending="false">
<Name>Uptime</Name>
<Description>Uptime</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>2</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="215">
<Name>Tools</Name>
<Type>write</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Message>Are you sure to exec this command?</Message>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>14</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type width="110">button</Type>
<Discreets>
<Discreet>
<Display>Config Package</Display>
<Value>Button1_InternalValue</Value>
</Discreet>
<Discreet>
<Display>Debug Package</Display>
<Value>Button2_InternalValue</Value>
</Discreet>
<Discreet>
<Display>Reboot</Display>
<Value>Button3_InternalValue</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="116" trending="false">
<Name>MemoryTotal</Name>
<Description>Memory Total</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>double</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>1</Row>
</Position>
</Positions>
<Units>GiB</Units>
<Range>
<Low>0</Low>
<High>256</High>
</Range>
</Display>
<Measurement>
<Type>number</Type>
</Measurement>
</Param>
<Param id="117" trending="true">
<Name>MemoryUsed</Name>
<Description>Memory Used</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>double</Type>
</Interprete>
<Alarm>
</Alarm>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>2</Row>
</Position>
</Positions>
<Units>GiB</Units>
<Range>
<Low>0</Low>
<High>256</High>
</Range>
</Display>
<Measurement>
<Type>number</Type>
</Measurement>
</Param>
<Param id="118" trending="true">
<Name>MemoryUtilized</Name>
<Description>Memory Utilized</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Alarm>
<CH>90</CH>
<Normal>70</Normal>
<CL>10</CL>
</Alarm>
<Interprete>
<Type>double</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>3</Row>
</Position>
</Positions>
<Units>%</Units>
<Range>
<Low>0</Low>
<High>100</High>
</Range>
</Display>
<Measurement>
<Type>analog</Type>
</Measurement>
</Param>
<Param id="119" trending="false">
<Name>DiskTotal</Name>
<Description>Disk Total</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Alarm>
</Alarm>
<Interprete>
<Type>double</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>4</Row>
</Position>
</Positions>
<Units>GiB</Units>
<Range>
<Low>0</Low>
<High>5120</High>
</Range>
</Display>
<Measurement>
<Type>number</Type>
</Measurement>
</Param>
<Param id="120" trending="true">
<Name>DiskUsed</Name>
<Description>Disk Used</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Alarm>
</Alarm>
<Interprete>
<Type>double</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>5</Row>
</Position>
</Positions>
<Units>GiB</Units>
<Range>
<Low>0</Low>
<High>5120</High>
</Range>
</Display>
<Measurement>
<Type>number</Type>
</Measurement>
</Param>
<Param id="121" trending="true">
<Name>DiskUtilized</Name>
<Description>Disk Utilized</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>double</Type>
</Interprete>
<Alarm>
</Alarm>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>6</Row>
</Position>
</Positions>
<Range>
<Low>0</Low>
<High>100</High>
</Range>
<Units>GiB</Units>
<Range>
<Low>0</Low>
<High>5120</High>
</Range>
</Display>
<Measurement>
<Type>number</Type>
</Measurement>
</Param>
<Param id="122" trending="true">
<Name>DiskPercent</Name>
<Description>Disk Percent</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>double</Type>
</Interprete>
<Alarm>
<CH>90</CH>
<WaH>80</WaH>
<Normal>60</Normal>
</Alarm>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>7</Row>
</Position>
</Positions>
<Units>%</Units>
<Range>
<Low>0</Low>
<High>100</High>
</Range>
</Display>
<Measurement>
<Type>analog</Type>
</Measurement>
</Param>
<Param id="123" trending="false">
<Name>CPUInfo</Name>
<Description>CPU Info</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>2</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="124" trending="false">
<Name>Core</Name>
<Description>Core Host</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>double</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>3</Row>
</Position>
</Positions>
<Units>C</Units>
<Range>
<Low>0</Low>
<High>128</High>
</Range>
</Display>
<Measurement>
<Type>number</Type>
</Measurement>
</Param>
<Param id="125" trending="false">
<Name>ProcessorFrecuency</Name>
<Description>Processor Frecuency</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>4</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="126" trending="true">
<Name>CPULoad</Name>
<Description>CPU Load</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>double</Type>
</Interprete>
<Alarm>
<Normal>60</Normal>
<WaH>80</WaH>
<CH>90</CH>
</Alarm>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>1</Row>
</Position>
</Positions>
<Units>%</Units>
<Range>
<Low>0</Low>
<High>100</High>
</Range>
</Display>
<Measurement>
<Type>analog</Type>
</Measurement>
</Param>
<Param id="226">
<Name>Module</Name>
<Type>write</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>10</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type width="110">pagebutton</Type>
<Discreets>
<Discreet>
<Display>Module...</Display>
<Value>Module</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="127" trending="false">
<Name>NMOSInterface</Name>
<Description>NMOS Interface</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Page>Management</Page>
<Column>0</Column>
<Row>1</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="227" setter="true">
<Type>write</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="128" trending="false">
<Name>NMOSIPAddress</Name>
<Description>NMOS IP Address</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>2</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="228" setter="true">
<Type>write</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="129" trending="false">
<Name>NMOSPort</Name>
<Description>NMOS Port</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>3</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="229" setter="true">
<Type>write</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="130" trending="false">
<Name>SNMPWRCommunity</Name>
<Description>SNMP Community RW</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>6</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="230" setter="true">
<Type>write</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="131" trending="false">
<Name>SNMPROCommunity</Name>
<Description>SNMP Community RO</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>5</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="231" setter="true">
<Type>write</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="132" trending="false">
<Name>Date</Name>
<Description>Date</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>5</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="232" setter="true">
<Name>Date</Name>
<Type>write</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type options="datetime">number</Type>
</Measurement>
</Param>
<Param id="133" trending="false">
<Name>UNIXTime</Name>
<Description>UNIX Time</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>6</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="134" trending="false">
<Name>TimeZome</Name>
<Description>Time Zone</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>7</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="234" setter="true">
<Type>write</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
<Discreets dependencyId="9" />
</Measurement>
</Param>
<Param id="135" trending="false" save="true">
<Name>username</Name>
<Description>Username</Description>
<Type>read</Type>
<Information>
<Subtext>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>3</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="235" setter="true">
<Type>write</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>3</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="136" trending="false" save="true">
<Name>Password</Name>
<Description>Password</Description>
<Type>read</Type>
<Information>
<Subtext>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>4</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type options="Password">string</Type>
</Measurement>
</Param>
<Param id="236" setter="true">
<Type>write</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>4</Row>
</Position>
</Positions>
</Display>
<Measurement>
</Measurement>
</Param>
<Param id="137">
<Name>DeleteAalarm</Name>
<Description></Description>
<Message>Do you want delete alarms?</Message>
<Type>write</Type>
<Information>
<Subtext>A</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Page>Alarms</Page>
<Column>0</Column>
<Row>1</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Discreets>
<Discreet>
<Display>Clean Alarms</Display>
<Value>delete</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="138">
<Name>LoginRelease</Name>
<Type>write</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Discreets>
<Discreet>
<Display>Login</Display>
<Value>Login</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="239">
<Name>Sensor</Name>
<Type>write</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>11</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Discreets>
<Discreet>
<Display>Sensor...</Display>
<Value>Sensor</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="240">
<Name>License</Name>
<Type>write</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>12</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Discreets>
<Discreet>
<Display>License...</Display>
<Value>License</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="141" trending="true">
<Name>NTPStatus</Name>
<Description>NTP Status</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<Normal>Enabled</Normal>
<CH>Disabled</CH>
</Alarm>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>2</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
<Discreets>
<Discreet>
<Display>Enabled</Display>
<Value>0\1</Value>
</Discreet>
<Discreet>
<Display>Disabled</Display>
<Value>0</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="142" trending="true">
<Name>NTPState</Name>
<Description>NTP State</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<Normal>Sync</Normal>
<CH>Not Sync</CH>
</Alarm>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>3</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
<Discreets>
<Discreet>
<Display>Not Sync</Display>
<Value>0</Value>
</Discreet>
<Discreet>
<Display>Sync</Display>
<Value>1</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="143" trending="true">
<Name>EnableTraps</Name>
<Description>Trap Status</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<CH>Disabled</CH>
</Alarm>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>7</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
<Discreets>
<Discreet>
<Value>true</Value>
</Discreet>
<Discreet>
<Value>false</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="144" trending="false">
<Name>TrapIP1</Name>
<Description>Trap IP Address  1</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>8</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="145" trending="false">
<Name>TrapIP2</Name>
<Description>Trap IP Address  2</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>9</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="146" trending="false">
<Name>TrapIP3</Name>
<Description>Trap IP Address  3</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>10</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="147" trending="false">
<Name>TrapIP4</Name>
<Description>Trap IP Address  4</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>11</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="148" trending="true">
<Name>EnableSyslogForwarding</Name>
<Description>Syslog</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<CL>Disabled</CL>
</Alarm>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>12</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
<Discreets>
<Discreet>
<Value>True</Value>
</Discreet>
<Discreet>
<Value>False</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="149" trending="false">
<Name>SyslogProtocol</Name>
<Description>Protocol</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>13</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="150" trending="false">
<Name>ClientAddress</Name>
<Description>Client Address</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>14</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="151" trending="false">
<Name>ClientPort</Name>
<Description>Client Port</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>15</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="152" trending="false">
<Name>CaptureDuration</Name>
<Description>Capture Duration</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>double</Type>
</Interprete>
<Alarm>
</Alarm>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>9</Row>
</Position>
</Positions>
<Units>min</Units>
<Range>
<Low>0</Low>
<High>100</High>
</Range>
</Display>
<Measurement>
<Type>number</Type>
</Measurement>
</Param>
<Param id="153" trending="false">
<Name>ConfirmServiceStop</Name>
<Description>Confirm Service Stop</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<CL>Disabled</CL>
</Alarm>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>10</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
<Discreets>
<Discreet>
<Value>True</Value>
</Discreet>
<Discreet>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="154" trending="true">
<Name>ConfirmServiceSave</Name>
<Description>Confirm Service Save</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<CL>Disabled</CL>
</Alarm>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>11</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
<Discreets>
<Discreet>
<Value>True</Value>
</Discreet>
<Discreet>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="155" trending="true">
<Name>ConfirmServiceRestart</Name>
<Description>Confirm Service Restart</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<CL>Disabled</CL>
</Alarm>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>12</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
<Discreets>
<Discreet>
<Value>True</Value>
</Discreet>
<Discreet>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="156" trending="true">
<Name>MuteServices</Name>
<Description>Mute Services</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<CL>Disabled</CL>
</Alarm>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>14</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
<Discreets>
<Discreet>
<Value>True</Value>
</Discreet>
<Discreet>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="157" trending="true">
<Name>MuteServicesOnBoot</Name>
<Description>Mute Services on Boot</Description>
<Type>read</Type>
<Information>
<Subtext>
<![CDATA[.]]>
</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<CL>Disabled</CL>
</Alarm>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>13</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
<Discreets>
<Discreet>
<Value>True</Value>
</Discreet>
<Discreet>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="158" trending="false" save="true">
<Name>key</Name>
<Description>License Key</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>5</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="258" setter="true">
<Name>key</Name>
<Type>write</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>5</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="159" trending="false">
<Name>SupportExpireDate</Name>
<Description>Support Valid Until</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>6</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="160" trending="false">
<Name>SupportStatus</Name>
<Description>Support Status</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>7</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="161" trending="false">
<Name>Token</Name>
<Description>Token</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Column>1</Column>
<Row>2</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1000">
<Name>ModuleStatusTable</Name>
<Description>Module Status</Description>
<Type>array</Type>
<ArrayOptions index="0">
<ColumnOption idx="0" pid="1001" type="retrieved" options=""/>
<ColumnOption idx="1" pid="1002" type="retrieved" options=";save" />
</ArrayOptions>
<Information>
<Subtext>tableInformation</Subtext>
</Information>
<Display>
<Positions>
<Position>
<Page>Module</Page>
<Column>0</Column>
<Row>0</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type options="tab=columns:1001|0-1002|1,width:100-100,sort:STRING-STRING,lines:25,filter:true">table</Type>
</Measurement>
</Param>
<Param id="1001" trending="false">
<Name>ModuleStatusTableName</Name>
<Description>Name</Description>
<Type>read</Type>
<Information>
<Subtext>This is the key used internally by DataMiner to identify the table entries.</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1002" trending="true">
<Name>ModuleStatusTableStatus</Name>
<Description>Status</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<CL>idle</CL>
<Normal>active</Normal>
<CH>inactive</CH>
</Alarm>
<Display>
</Display>
<Measurement>
<Type>string</Type>
<Discreets>
<Discreet>
<Display>Running</Display>
<Value>active</Value>
</Discreet>
<Discreet>
<Display>Not Running</Display>
<Value>inactive</Value>
</Discreet>
<Discreet>
<Display>Idle</Display>
<Value>idle</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="1200">
<Name>AlarmTable</Name>
<Description>Alarms of Titan Live</Description>
<Type>array</Type>
<ColumnOption idx="0" pid="1201" type="retrieved" options=""/>
<ColumnOption idx="1" pid="1202" type="retrieved" options=""/>
<ColumnOption idx="2" pid="1203" type="retrieved" options=""/>
<ColumnOption idx="3" pid="1204" type="retrieved" options=""/>
<ColumnOption idx="4" pid="1205" type="retrieved" options=""/>
<ColumnOption idx="5" pid="1206" type="retrieved" options=""/>
</ArrayOptions>
<Information>
</Information>
<Display>
<Positions>
<Position>
<Page>Alarms</Page>
<Column>0</Column>
<Row>0</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type options="tab=columns:1201|0-1202|1-1203|2-1204|3-1205|4-1206|5,width:180-120-180-180-480-150,sort:STRING-STRING-STRING-STRING-STRING-STRING,lines:25,filter:true">table</Type>
</Measurement>
</Param>
<Param id="1201" trending="false">
<Name>AlarmTableType</Name>
<Description>Type</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
</Alarm>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1202" trending="false">
<Name>AlarmTableDate</Name>
<Description>Start Date</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1203" trending="false">
<Name>AlarmTableLevel</Name>
<Description>Level</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<CH>critical</CH>
</Alarm>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1204" trending="false">
<Name>AlarmTableIssue</Name>
<Description>Issue</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
</Alarm>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1205" trending="false">
<Name>AlarmTableDescription</Name>
<Description>Description</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1206" trending="false">
<Name>AlarmTableService</Name>
<Description>Service</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
</Alarm>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1400">
<Name>LicenseTable</Name>
<Description>License</Description>
<Type>array</Type>
<ColumnOption idx="0" pid="1401" type="retrieved" options=""/>
<ColumnOption idx="1" pid="1402" type="retrieved" options=""/>
<ColumnOption idx="2" pid="1403" type="retrieved" options=""/>
<ColumnOption idx="3" pid="1404" type="retrieved" options=""/>
</ArrayOptions>
<Information>
</Information>
<Display>
<Positions>
<Position>
<Column>0</Column>
<Row>3</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type options="tab=columns:1401|0-1402|1-1403|2-1404|3,width:111-100-100-114,sort:STRING-STRING-STRING-STRING,lines:25,filter:true">table</Type>
</Measurement>
</Param>
<Param id="1401" trending="false">
<Name>LicenseTableName</Name>
<Description>License Name</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1402" trending="false">
<Name>LicenseTableType</Name>
<Description>License Type</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1403" trending="false">
<Name>LicenseTableTotal</Name>
<Description>License Total</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1404" trending="false">
<Name>LicenseTableAvailable</Name>
<Description>License Available</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<Normal>!=0</Normal>
<CH>0</CH>
</Alarm>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1600">
<Name>HardwareSensor</Name>
<Description>Hardware</Description>
<Type>array</Type>
<ColumnOption idx="0" pid="1601" type="retrieved" options=""/>
<ColumnOption idx="1" pid="1602" type="retrieved" options=""/>
<ColumnOption idx="2" pid="1603" type="retrieved" options=""/>
</ArrayOptions>
<Information>
</Information>
<Display>
<Positions>
<Position>
<Page>Sensor</Page>
<Column>0</Column>
<Row>0</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type options="tab=columns:1601|0-1602|1-1603|2,width:125-104-115,sort:STRING-STRING-STRING,lines:25,filter:true">table</Type>
</Measurement>
</Param>
<Param id="1601" trending="false">
<Name>HardwareSensorName</Name>
<Description>Hardware Name</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1602" trending="false">
<Name>HardwareSensorType</Name>
<Description>Hardware Type</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1603" trending="true">
<Name>HardwareSensorValue</Name>
<Description>Hardware Sensor</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<Normal>50</Normal>
<CH>100</CH>
</Alarm>
<Display>
<Range>
<Low>0</Low>
<High>100</High>
</Range>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1800" trending="true">
<Name>Servicetable</Name>
<Description>Table of Services</Description>
<Type>array</Type>
<ArrayOptions index="0" options=";naming=/1802">
<ColumnOption idx="0" pid="1801" type="retrieved" options=""/>
<ColumnOption idx="1" pid="1802" type="retrieved" options=""/>
<ColumnOption idx="2" pid="1803" type="retrieved" options=""/>
<ColumnOption idx="3" pid="1804" type="retrieved" options=""/>
<ColumnOption idx="4" pid="1805" type="retrieved" options=""/>
</ArrayOptions>
<Information>
<Subtext>
<![CDATA[Table Of Services]]>
</Subtext>
</Information>
<Display>
<Positions>
<Position>
<Page>Services</Page>
<Column>0</Column>
<Row>0</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type options="tab=columns:1801|0-1802|1-1803|2-1804|3-1805|4,width:100-100-100-100-100,sort:STRING-STRING-STRING-STRING-STRING,lines:10,filter:true">table</Type>
</Measurement>
</Param>
<Param id="1801" trending="false">
<Name>ServiceTableUUID</Name>
<Description>UID</Description>
<Type>read</Type>
<Information>
<Subtext>1</Subtext>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1802" trending="false">
<Name>ServiceTableService</Name>
<Description>Service Name</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
</Alarm>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1902" setter="true">
<Type>write</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="1803" trending="true">
<Name>ServiceTableStateService</Name>
<Description>Service Status</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<Normal>Encoding</Normal>
<CH>Invalid</CH>
<WaH>Stopped</WaH>
<CL>Pending</CL>
<MiL>Starting</MiL>
<WaL>Unknown</WaL>
</Alarm>
<Display>
</Display>
<Measurement>
<Discreets>
<Discreet>
<Display>Stopped</Display>
<Value>Stopped</Value>
</Discreet>
<Discreet>
<Display>Encoding</Display>
<Value>Encoding</Value>
</Discreet>
<Discreet>
<Display>Starting</Display>
<Value>Starting</Value>
</Discreet>
<Discreet >
<Display>Invalid</Display>
<Value>Invalid</Value>
</Discreet>
<Discreet>
<Display>Pending</Display>
<Value>Pending</Value>
</Discreet>
<Discreet>
<Display>Unknown</Display>
<Value>Unknown</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="1903" setter="true">
<Type>write</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>togglebutton</Type>
<Discreets>
<Discreet>
<Display>Stop</Display>
</Discreet>
<Discreet>
<Display>Start</Display>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="1804" trending="true">
<Name>ServiceTableChunk</Name>
<Description>Chunk</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<Normal>Enable</Normal>
<CH>Disable</CH>
</Alarm>
<Display>
</Display>
<Measurement>
<Type>string</Type>
<Discreets>
<Discreet>
<Display>Enable</Display>
<Value>1</Value>
</Discreet>
<Discreet>
<Display>Disable</Display>
<Value>0</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="1904" setter="true">
<Type>write</Type>
<Information>
</Information>
<Interprete>
<Type>double</Type>
</Interprete>
<Display>
</Display>
<Measurement>
</Measurement>
</Param>
<Param id="1805" trending="false">
<Name>ServiceTableBlackout</Name>
<Description>Blackout</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
<CH>Disable</CH>
</Alarm>
<Display>
</Display>
<Measurement>
<Type>string</Type>
<Discreets>
<Discreet>
<Value>1</Value>
</Discreet>
<Discreet>
<Value>0</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
<Param id="1905" setter="true">
<Type>write</Type>
<Interprete>
<Type>double</Type>
</Interprete>
<Display>
</Display>
<Measurement>
</Measurement>
</Param>
<Param id="2000">
<Name>NetworkTable2</Name>
<Description>Interfaces Table</Description>
<Type>array</Type>
<ColumnOption idx="0" pid="2001" type="retrieved" options=""/>
<ColumnOption idx="1" pid="2002" type="retrieved" options="" />
<ColumnOption idx="2" pid="2003" type="retrieved" options="" />
<ColumnOption idx="3" pid="2004" type="retrieved" options="" />
<ColumnOption idx="4" pid="2005" type="retrieved" options="" />
<ColumnOption idx="5" pid="2006" type="retrieved" options="" />
<ColumnOption idx="6" pid="2007" type="retrieved" options="" />
<ColumnOption idx="7" pid="2008" type="retrieved" options="" />
<ColumnOption idx="8" pid="2009" type="retrieved" options="" />
<ColumnOption idx="9" pid="2010" type="retrieved" options=""/>
</ArrayOptions>
<Information>
</Information>
<Display>
<Positions>
<Position>
<Page>Networking</Page>
<Column>0</Column>
<Row>0</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Type options="tab=columns:2001|0-2002|1-2003|2-2004|3-2005|4-2006|5-2007|6-2008|7-2009|8-2010|9,width:100-100-121-100-100-101-100-100-100-100,sort:STRING-STRING-STRING-STRING-STRING-STRING-STRING-STRING-STRING-STRING,lines:25,filter:true">table</Type>
</Measurement>
</Param>
<Param id="2001" trending="false">
<Name>NetworkTable2InterfaceName</Name>
<Description>Interface</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="2002" trending="false">
<Name>NetworkTable2LogicalName</Name>
<Description>Logical Name</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
</Alarm>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="2003" trending="false">
<Name>NetworkTable2NegociatedSpeed</Name>
<Description>Negociated Speed</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Alarm>
</Alarm>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="2004" trending="false">
<Name>NetworkTable2Speed</Name>
<Description>Speed</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="2005" trending="false">
<Name>NetworkTable2LinkStatus</Name>
<Description>Link Status</Description>
<Type>read</Type>
<Information>
</Information>
<Alarm>
<Normal>Up</Normal>
<CH>Down</CH>
</Alarm>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="2006" trending="false">
<Name>NetworkTable2InterfaceState</Name>
<Description>Interface State</Description>
<Type>read</Type>
<Information>
</Information>
<Alarm>
<Normal>connected</Normal>
<CH>not connected</CH>
</Alarm>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="2007" trending="false">
<Name>NetworkTable2Method</Name>
<Description>Method</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="2008" trending="false">
<Name>NetworkTable2IPAddress</Name>
<Description>IP Address</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="2009" trending="false">
<Name>NetworkTable2Mask</Name>
<Description>Net Mask</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Param id="2010" trending="false">
<Name>NetworkTable2IGMP</Name>
<Description>IGMP</Description>
<Type>read</Type>
<Information>
</Information>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
</Params>
<QActions>
<QAction id="1" name="Precompiled Code" encoding="csharp" options="precompile" />
<QAction id="2" name="After Startup" encoding="csharp" triggers="1" />
<QAction id="3" name="Ping Status" encoding="csharp" triggers="3" />
<QAction id="4" name="Upper MAC" encoding="csharp" triggers="23"/>
<QAction id="5" name="NMOS" encoding="csharp" triggers="27"/>
<QAction id="6" name="Firmware" encoding="csharp" triggers="8"/>
<QAction id="7" name="Resources" encoding="csharp" triggers="11"/>
<QAction id="8" name="Memory" encoding="csharp" triggers="13"/>
<QAction id="9" name="CPU" encoding="csharp" triggers="15"/>
<QAction id="10" name="Module" encoding="csharp" triggers="17"/>
<QAction id="11" name="Alarms" encoding="csharp" triggers="19"/>
<QAction id="12" name="Date" encoding="csharp" triggers="29"/>
<QAction id="13" name="SNMP" encoding="csharp" triggers="31"/>
<QAction id="14" name="Syslog" encoding="csharp" triggers="33"/>
<QAction id="15" name="Options" encoding="csharp" triggers="35"/>
<QAction id="16" name="Service" encoding="csharp" triggers="39"/>
<QAction id="17" name="Network Monitor" encoding="csharp" triggers="37"/>
<QAction id="19" name="License" encoding="csharp" triggers="37"/>
<QAction id="20" name="GET URL Service Name" encoding="csharp" row="true" triggers="1902"/>
<QAction id="21" name="Update Service Name" encoding="csharp"  triggers="40"/>
<QAction id="24" name="Token" encoding="csharp"   triggers="5"/>
</QActions>
<HTTP>
<Session id="1" name="GET API Status NET">
<Connection id="1" name="Check Ping">
<Request verb="GET" url="api/v1/system/network/ping">
</Request>
<Response statusCode="2">
<Content pid="3"></Content>
</Response>
</Connection>
</Session>
<Session id="2" name="GET Firmware UPDT" loginMethod="credentials" userName="135" password="136" >
<Connection id="2" name="firmware">
<Request verb="GET" url="api/v1/system/updater/firmware">
<Headers>
<Header key="cache-control">no-cache</Header>
</Headers>
</Request>
<Response statusCode="7">
<Content pid="8"></Content>
</Response>
</Connection>
</Session>
<Session id="3" name="GET Alarms MNGT" loginMethod="credentials" userName="135" password="136">
<Connection id="3">
<Request verb="GET" url="api/v1/alarmsmngt/alarms">
<Headers>
</Headers>
</Request>
<Response statusCode="18">
<Content pid="19"/>
</Response>
</Connection>
</Session>
<Session id="4" name="DEL Alarms MNGT" loginMethod="credentials" userName="135" password="136">
<Connection id="4">
<Request verb="DELETE" url="api/v1/alarmsmngt/alarms">
<Headers>
<Header key="Content-Type">application/json</Header>
</Headers>
</Request>
<Response statusCode="20">
<Content pid="21"/>
</Response>
</Connection>
</Session>
<Session id="5" name="GET Configuration MNGT" loginMethod="credentials" userName="135" password="136">
<Connection id="5">
<Request verb="GET" url="api/v1/alarmsmngt/configuration">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="6" name="PUT Configuration MNGT" loginMethod="credentials" userName="135" password="136">
<Connection id="6">
<Request verb="PUT" url="api/v1/alarmsmngt/configuration">
<Data pid="2"/>
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="7" name="GET Services SRV" loginMethod="credentials" userName="135" password="136">
<Connection id="7">
<Request verb="GET" url="api/v1/servicesmngt/services">
<Headers>
</Headers>
</Request>
<Response statusCode="38">
<Content pid="39"/>
</Response>
</Connection>
</Session>
<Session id="8" name="GET Date CONF" loginMethod="credentials" userName="135" password="136">
<Connection id="8">
<Request verb="GET" url="api/v1/system/configuration/time/date">
<Headers>
</Headers>
</Request>
<Response statusCode="28">
<Content pid="29"/>
</Response>
</Connection>
</Session>
<Session id="9" name="GET Time CONF" loginMethod="credentials" userName="135" password="136">
<Connection id="9">
<Request verb="GET" url="api/v1/system/configuration/time/configuration">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="10" name="PUT Time CONF" loginMethod="credentials" userName="135" password="136">
<Connection id="10">
<Request verb="PUT" url="api/v1/system/configuration/time/configuration">
<Data pid="2"/>
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="11" name="POST Probe SRV" loginMethod="credentials" userName="135" password="136">
<Connection id="11">
<Request verb="POST" url="api/v1/servicesmngt/probe">
<Data pid="2"/>
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="12" name="GET MaxLoad SRV" loginMethod="credentials" userName="135" password="136">
<Connection id="12">
<Request verb="GET" url="api/v1/servicesmngt/maxload">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="13" name="GET Load SRV" loginMethod="credentials" userName="135" password="136">
<Connection id="13">
<Request verb="GET" url="api/v1/servicesmngt/load">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="14" name="GET Version INF" loginMethod="credentials" userName="135" password="136">
<Connection id="14">
<Request verb="GET" url="api/v1/system/information/version">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="15" name="GET Logos CONF" loginMethod="credentials" userName="135" password="136">
<Connection id="15">
<Request verb="GET" url="api/v1/system/configuration/logos">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="16" name="GET Fonts CONF" loginMethod="credentials" userName="135" password="136">
<Connection id="16">
<Request verb="GET" url="api/v1/system/configuration/fonts">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="17" name="POST Reboot INF" loginMethod="credentials" userName="135" password="136">
<Connection id="17">
<Request verb="POST" url="api/v1/system/information/reboot">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="18" name="GET State UPD" loginMethod="credentials" userName="135" password="136">
<Connection id="18">
<Request verb="GET" url="api/v1/system/updater/state">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="19" name="GET Splice SRV" loginMethod="credentials" userName="135" password="136">
<Connection id="19">
<Request verb="GET" url="api/v1/servicesmngt/splice">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="20" name="GET State SRV" loginMethod="credentials" userName="135" password="136">
<Connection id="20">
<Request verb="GET" url="api/v1/servicesmngt/services/state">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="21" name="GET Interface1 HW" loginMethod="credentials" userName="135" password="136">
<Connection id="21">
<Request verb="GET" url="api/v1/system/network/interfaces/physical">
<Headers>
</Headers>
</Request>
<Response statusCode="36">
<Content pid="37"/>
</Response>
</Connection>
</Session>
<Session id="22" name="GET Interface2 HW" loginMethod="credentials" userName="135" password="136">
<Connection id="22">
<Request verb="GET" url="api/v1/system/network/interfaces/vlan">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="23" name="GET SNMP CONF" loginMethod="credentials" userName="135" password="136">
<Connection id="23">
<Request verb="GET" url="api/v1/system/configuration/snmp/configuration">
<Headers>
</Headers>
</Request>
<Response statusCode="30">
<Content pid="31"/>
</Response>
</Connection>
</Session>
<Session id="24" name="PUT SNMP CONF" loginMethod="credentials" userName="135" password="136">
<Connection id="24">
<Request verb="PUT" url="api/v1/system/configuration/snmp/configuration">
<Data pid="2"/>
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="25" name="GET Fingerprint LIC" loginMethod="credentials" userName="135" password="136">
<Connection id="25">
<Request verb="GET" url="api/v1/system/licensing/fingerprint">
<Headers>
</Headers>
</Request>
<Response statusCode="24">
<Content pid="25"/>
</Response>
</Connection>
</Session>
<Session id="26" name="GET Features LIC" loginMethod="credentials" userName="135" password="136">
<Connection id="26">
<Request verb="GET" url="api/v1/system/licensing/features">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="27" name="GET ServerAddress LIC" loginMethod="credentials" userName="135" password="136">
<Connection id="27">
<Request verb="GET" url="api/v1/system/licensing/serverAddress">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="28" name="PUT ServerAddress LIC" loginMethod="credentials" userName="135" password="136">
<Connection id="28">
<Request verb="PUT" url="api/v1/system/licensing/serverAddress">
<Data pid="2"/>
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="29" name="GET Sensor HW" loginMethod="credentials" userName="135" password="136">
<Connection id="29">
<Request verb="GET" url="api/v1/system/hardware/sensors">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="30" name="POST DebugPackage INF" loginMethod="credentials" userName="135" password="136">
<Connection id="30">
<Request verb="POST" url="api/v1/system/information/debugpackage">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="31" name ="GET DebugPackage INF" loginMethod="credentials" userName="135" password="136">
<Connection id="31">
<Request verb="GET" url="api/v1/system/information/debugpackage">
<Headers>
</Headers>
</Request>
<Content pid="2"/>
</Response>
</Connection>
</Session>
<Session id="32" name="GET CPU INF" loginMethod="credentials" userName="135" password="136">
<Connection id="32">
<Request verb="GET" url="api/v1/system/information/cpu">
<Headers>
</Headers>
</Request>
<Response statusCode="14">
<Content pid="15"/>
</Response>
</Connection>
</Session>
<Session id="33" name="GET Disk UPDT" loginMethod="credentials" userName="135" password="136">
<Connection id="33">
<Request verb="GET" url="api/v1/system/updater/information/disk">
<Headers>
</Headers>
</Request>
<Response statusCode="10">
<Content pid="11"/>
</Response>
</Connection>
</Session>
<Session id="34" name="GET Memory INF" loginMethod="credentials" userName="135" password="136">
<Connection id="34">
<Request verb="GET" url="api/v1/system/information/memory">
<Headers>
</Headers>
</Request>
<Response statusCode="12">
<Content pid="13"/>
</Response>
</Connection>
</Session>
<Session id="35" name="GET Module INF" loginMethod="credentials" userName="135" password="136">
<Connection id="35">
<Request verb="GET" url="api/v1/system/information/status">
<Headers>
</Headers>
</Request>
<Response statusCode="16">
<Content pid="17"/>
</Response>
</Connection>
</Session>
<Session id="36" name="GET MAC LIC" loginMethod="credentials" userName="135" password="136">
<Connection id="36">
<Request verb="GET" url="api/v1/system/licensing/macAddress">
<Headers>
</Headers>
</Request>
<Response statusCode="22">
<Content pid="23" />
</Response>
</Connection>
</Session>
<Session id="37" name="GET NMOS MNGT" loginMethod="credentials" userName="135" password="136">
<Connection id="37">
<Request verb="GET" url="api/v1/system/configuration/nmos/configuration">
<Headers>
</Headers>
</Request>
<Response statusCode="26">
<Content pid="27"/>
</Response>
</Connection>
</Session>
<Session id="38" name="GET SYSLOG CONF" loginMethod="credentials" userName="135" password="136">
<Connection id="38">
<Request verb="GET" url="api/v1/system/configuration/syslog/configuration">
<Headers>
</Headers>
</Request>
<Response statusCode="32">
<Content pid="33"/>
</Response>
</Connection>
</Session>
<Session id="39" name="GET Services MNGT" loginMethod="credentials" userName="135" password="136">
<Connection id="39">
<Request verb="GET" url="api/v1/servicesmngt/configuration/services">
<Headers>
</Headers>
</Request>
<Response statusCode="34">
<Content pid="35"/>
</Response>
</Connection>
</Session>
<Session id="40" name="GET Token" loginMethod="credentials" userName="135" password="136">
<Connection id="40">
<Request verb="POST" url="api/v1/system/configuration/login">
<Data pid="6"/>
<Headers>
</Headers>
</Request>
<Response statusCode="4">
<Content pid="5"/>
</Response>
</Connection>
</Session>
<Session id="41" name="GET Custom URL Service" loginMethod="credentials" userName="135" password="136">
<Connection id="41">
<Request verb="GET" pid="40">
<Headers>
</Headers>
</Request>
<Response statusCode="41">
<Content pid="42"/>
</Response>
</Connection>
</Session>
<Session id="42" name="PUT Service Custom" loginMethod="credentials" userName="135" password="136">
<Connection id="42">
<Request verb="PUT" pid="40">
<Data pid="43"/>
<Headers>
</Headers>
</Request>
<Response statusCode="44">
<Content pid="45"/>
</Response>
</Connection>
</Session>
</HTTP>
<Groups>
<Group id="1">
<Name>After Startup</Name>
<Description>After Startup</Description>
<Type>poll action</Type>
<Content>
<Action>2</Action>
</Content>
</Group>
<Group id="2">
<Name>Fast Polling Session 10S</Name>
<Description>Fast Polling 10s</Description>
<Type>poll</Type>
<Content>
<Session>1</Session>
<Session>7</Session>
<Session>40</Session>
</Content>
</Group>
<Group id="3">
<Name>Fast Polling Action 10S</Name>
<Content>
<Action>3</Action>
</Content>
</Group>
<Group id="4">
<Name>Fast Polling Session 30S</Name>
<Description>Fast Polling 30S</Description>
<Type>poll</Type>
<Content>
<Session>8</Session>
<Session>3</Session>
<Session>32</Session>
<Session>33</Session>
<Session>34</Session>
<Session>35</Session>
</Content>
</Group>
<Group id="5">
<Name>DeleteAlarms</Name>
<Description>Delete Alarms</Description>
<Type>poll</Type>
<Content>
<Session>4</Session>
</Content>
</Group>
<Group id="6">
<Name>Slow Polling Session 1m</Name>
<Description>Slow Polling 1m</Description>
<Type>poll</Type>
<Content>
<Session>2</Session>
<Session>21</Session>
<Session>23</Session>
<Session>25</Session>
<Session>36</Session>
<Session>37</Session>
<Session>38</Session>
<Session>39</Session>
</Content>
</Group>
<Group id="7">
<Name>UpdateServiceName</Name>
<Description>Update Service name</Description>
<Content>
<Action>7</Action>
</Content>
</Group>
<Group id="8">
<Name>Slow Polling Session 5m</Name>
<Description>Slow Polling 5m</Description>
<Type>poll</Type>
<Content>
</Content>
</Group>
<Group id="9">
<Name>PutCustomURLServiceName1</Name>
<Description>Custom URL Update Service name Action</Description>
<Content>
<Action>9</Action>
</Content>
</Group>
<Group id="10">
<Name>PutCustomURLServiceName2</Name>
<Description>Custom URL Update Service name Session</Description>
<Type>poll</Type>
<Content>
<Session>41</Session>
</Content>
</Group>
<Group id="11">
<Name>PutURLServiceName1</Name>
<Description>Custom URL Update Service name</Description>
<Content>
<Action>11</Action>
</Content>
</Group>
<Group id="12">
<Name>PutURLServiceName2</Name>
<Type>poll</Type>
<Content>
<Session>42</Session>
</Content>
</Group>
</Groups>
<Triggers>
<Trigger id="1">
<On>protocol</On>
<Time>after startup</Time>
<Type>action</Type>
<Content>
<Id>1</Id>
</Content>
</Trigger>
<Trigger id="2">
<On id="137">parameter</On>
<Time>change</Time>
<Type>action</Type>
<Content>
<Id>4</Id>
</Content>
</Trigger>
<Trigger id="3">
<On id="1902">parameter</On>
<Time>change</Time>
<Type>action</Type>
<Content>
<Id>6</Id>
</Content>
</Trigger>
<Trigger id="4">
<Name>CustomURLServiceName</Name>
<On id="40">parameter</On>
<Time>change</Time>
<Type>action</Type>
<Content>
<Id>8</Id>
</Content>
</Trigger>
<Trigger id="5">
<Name>CustomServiceName</Name>
<On id="43">parameter</On>
<Time>change</Time>
<Type>action</Type>
<Content>
<Id>10</Id>
</Content>
</Trigger>
</Triggers>
<Actions>
<Action id="1">
<Name>After Startup Group</Name>
<On id="1">group</On>
<Type>execute next</Type>
</Action>
<Action id="2">
<Name>After Startup QAction</Name>
<On id="1">parameter</On>
<Type>run actions</Type>
</Action>
<Action id="3">
<Name>Run Ping Check</Name>
<On id="3">parameter</On>
</Action>
<Action id="4">
<Name>Delete Alarms</Name>
<On id="5">group</On>
<Type>execute one now</Type>
</Action>
<Action id="5">
<Name>Run Check Support</Name>
<On id="101">parameter</On>
</Action>
<Action id="6">
<Name>Update Service Name Group</Name>
<On id="7">group</On>
</Action>
<Action id="7">
<Name>Update Service Name QAction</Name>
<On id="10">group</On>
</Action>
<Action id="8">
<Name>Set URL Service Name Group</Name>
<On id="9">group</On>
</Action>
<Action id="9">
<Name>Set URL Service Name QAction</Name>
</Action>
<Action id="10">
<Name>Put Service Name Group</Name>
<On id="11">group</On>
</Action>
<Action id="11">
<Name>Put Service Name QAction</Name>
<On id="12">group</On>
</Action>
<!--<Action id="99">
<Name>Copy 23 To 112</Name>
<On id="112">parameter</On>
<Type id="23">copy</Type>
</Action>-->
</Actions>
<Timers>
<Timer id="1">
<Name>Fast Timer (10s)</Name>
<Time initial="true">10000</Time>
<Interval>75</Interval>
<Content>
<Group>2</Group>
</Content>
</Timer>
<Timer id="2">
<Name>Medium Timer (1m)</Name>
<Time initial="true" dataDisplay="30000">60000</Time>
<Content>
<Group>3</Group>
<Group>6</Group>
</Content>
</Timer>
<Timer id="3">
<Name>Slow Timer (30S)</Name>
<Time initial="true">30000</Time>
<Content>
<Group>4</Group>
</Content>
</Timer>
<Timer id="4">
<Name>Slow Timer (5m)</Name>
<Time initial="true">3000000</Time>
<Content>
<Group>8</Group>
</Content>
</Timer>
</Timers>
<PortSettings name="HTTP Connection">
<BusAddress>
<DefaultValue>ByPassProxy</DefaultValue>
<Disabled>false</Disabled>
</BusAddress>
<IPport>
<DefaultValue>80</DefaultValue>
</IPport>
</PortSettings>
</Protocol>
First attempt
Second Attempt
The PUT request only sends the correct values to the API on the second attempt
Jose Araujo [DevOps Advocate] Selected answer as best 4th July 2025
Jose Araujo [DevOps Advocate]1.01K Posted 4th July 2025 0 Comments
Found the problem, I had set it wrong in the Triggers, which caused the QActions to run before the parameter was set.
I add double check validation value in QAction:
using System;
using Skyline.DataMiner.Scripting;
public class QAction
public void Run(SLProtocol protocol)
try
string rowKey = protocol.RowKey();
string ip = protocol.GetParameter(Parameter.nmosipaddress) as string;
string newName = Convert.ToString(protocol.GetParameter(protocol.GetTriggerParameter()));
if (string.IsNullOrWhiteSpace(rowKey) || string.IsNullOrWhiteSpace(ip) || string.IsNullOrWhiteSpace(newName))
return;
string getUrl = $"http://{ip}/api/v1/servicesmngt/services/{rowKey}";
protocol.SetParameter(Parameter.customurlservices, getUrl);
protocol.SetParameter(Parameter.newnameservice, newName);
int maxRetries = 20;
int attempts = 0;
bool success = false;
while (attempts < maxRetries && !success)
attempts++;
string checkName = protocol.GetParameter(Parameter.newnameservice)?.ToString();
if (!string.IsNullOrWhiteSpace(checkName) && checkName == newName)
success = true;
protocol.CheckTrigger(4)
else
if (!success)
catch (Exception ex)
protocol.Log("QA20Error en QA_GET: " + ex.Message, LogType.Error);
Jose Araujo [DevOps Advocate] Changed status to publish 4th July 2025
