Issue with installing a dmapp package that I created
Solved1.33K views10th October 2023dmapp
Joshua Lee [SLC] [DevOps Advocate]637 10th October 2023 0 Comments
After creating a dmapp package, I was not able to install it due to this error:
The dmapp package can be found at this link:
https://jenkins.skyline.be/job/Skyline/job/InstallPackages/job/I_Generic/job/I_G_OpenSearch/job/I_G_OpenSearch_Installer/job/1.0.X/29/artifact/Installer%201.0.1_B29.dmapp
Appreciate any insight on where I might have messed up when creating the dmapp, thanks!
Joshua Lee [SLC] [DevOps Advocate] Selected answer as best 10th October 2023
Michiel Oda [SLC] [DevOps Advocate]3.84K Posted 10th October 2023 1 Comment
Hi Joshua
I’ve downloaded the dmapp and I couldn’t reproduce this issue. It successfully installed everything. Even when I run it twice.
The error is about a missing install script. Could it be that it got removed during install (as in, you saw a ‘random’ script popup and removed that during installation)?
Joshua Lee [SLC] [DevOps Advocate] commented 10th October 2023
Hi Michiel, I ran it again and now it works for me as well. The only thing that I can think of is that I restarted my DMA but I’ve no idea if that was actually the fix.
Regarding your comment, I don’t think that happened. But thanks for the reply!
