Issue with Element Query in Low Code App
Solved1.07K views3rd March 2023low code apps
Jim Woodier [DevOps Member]765 3rd March 2023 0 Comments
Hello,
I'm building a low code app on a DMS version DataMiner (10.3.2.0-12627). When I try to create a query that references elements I get the error below.
Note that I have the same queries on a dev DMS running 10.3.1.0 and do not get the same error. The newer DMS is set up for TLS.... is this possible an issue?
Jim Woodier [DevOps Member] Selected answer as best 3rd March 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.45K Posted 3rd March 2023 0 Comments
Hi Jim,
This is an issue which was patched in 10.3.3.0 and is available for download as of today (see here).
Technical detail: It's a race condition in the web API which is typically resolved by restarting the web server (IIS).
