Issue with Cube connecting to Agent after configuring redirect to HTTPS
Solved2.42K views22nd November 2024Cube Desktop App
Andrew Teoh [DevOps Member]240 31st July 2024 1 Comment
Recently configured our DMA agents with a self-signed SSL certificate and also configured a HTTP redirect to HTTPS. After the configuration, the low-code apps could load normally on the browser (of course, there's the usual security warning as it's a self-signed certificate).
However, when I tried to connect to the Agent via Cube, I get this error:
Is this due to the self-signed certificate? If so, how can I workaround this?
Any advice is appreciated. Thanks!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 22nd November 2024
Vikas Choudhary [DevOps Member] commented 31st July 2024
We also faced same issue for LAB DMA with Self-Signed Certificate. It’s got fixed after adding in Trusted Folder. Please add certificate in trusted folder and try again. Hope It should work.
Thanks
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 31st July 2024 1 Comment
Could you also please verify that IIS and DataMiner are confgured to use HTTPS as well?
All information can be found in following link:
Setting up HTTPS on a DMA | DataMiner Docs
Make sure the certification address in DataMiner is the same as the one of the SSL certificate.
Example:
Hope this will help you further
Andrew Teoh [DevOps Member] Posted new comment 31st July 2024
Andrew Teoh [DevOps Member] commented 31st July 2024
Thank you.. Will give it a go as well…
