Issue in getting alarm history using GQI
Solved599 views5th November 2025alarmconsole GQI service
Hari priya Venkatesan [DevOps Advocate]1.06K 6th June 2025 2 Comments
Hi Team,
I'm using SLC-GQIDS-ServiceHistoryAlarms
for getting the history of alarms for a deleted service.
This GQI requires parameters like service name, start time and end time.
So i tried the service creation time and current time for end time fields but its giving no alarms found though there is alarm console for this period of time for the specific, What time should be given in the start and end time
Flavio Meneses [SLC] [DevOps Enabler]1.31K Posted 13th June 2025 0 Comments
Hi Priya,
I've recreated your scenario but was unable to reproduce the issue. Could you double-check that the start time is earlier than the time displayed in the "Time" column of the alarm console, while ensuring the end time is later than that value?
Kind regards,
