Is there OVA for creating a DataMiner as a VM or AMI for creating DataMiner AWS EC2 instance?
Solved3.05K views12th January 2023AWS VM
Srikanth Mandava [SLC] [DevOps Advocate]936 4th September 2020 0 Comments
I have installed DataMiner on my laptop and wondering there are automated way of installing the product as VM or cloud instance?
Srikanth Mandava [SLC] [DevOps Advocate] Selected answer as best 12th January 2023
Alberto De Luca [DevOps Enabler]5.75K Posted 19th October 2021 0 Comments
Hi Sri, I believe there is an option to build a custom AMI under this section - but it would be at AWS admin level. Perhaps something can be saved with just the OS and management and polling NICs, and the DMA software to perform the build:
Theoretically, SL could build one that is available as a 3rd party option in AWS Marketplace or the community - however for a "built-DMA" AMI,some considerations may be needed with the licensing team (e.g. to allow the DMA to start when using the AMI on a different instance).
