Is there a way to trigger automation scripts when a scheduled job starts/ends in MediaOps?
328 views22nd October 2025MediaOps
Jeremy Middle [DevOps Member]152 21st October 2025 0 Comments
I'm looking to test the MediaOps scheduler and want to schedule certain parameters to change (start/stop MediaConnect, TAG VS monitor and Decoder). This would be a way to automate our feeds and ensure we are only monitoring when we need to as well. I see there is a way to create a service, I'm open to this as well, but we have high density decoders and mediaconnect elements that have multiple decodes or flows. It's not really clear how to select a certain flow/decode. These are things that would be nice to automate if there is a way!
Thank you.
Joey Vanhalst [SLC] [DevOps Advocate] Answered question 22nd October 2025
Joey Vanhalst [SLC] [DevOps Advocate]2.13K Posted 22nd October 2025 0 Comments
Hi Jeremy, the same answer from this question also applies: Media Ops workflow to create a cube monitoring service from a service template when the job starts? - DataMiner Dojo.
As long as supporting orchestration scripts for these actions at start/stop are not yet released, the same workaround can be used as mentioned in that question (both to create a service and to apply certain settings to resources).
