Is there a way to overwrite decimal places of a column parameter
Solved2.83K views27th March 2023dynamicunits
Geovanny Galeano [SLC] [DevOps Advocate]820 5th July 2022 0 Comments
Our driver has some column parameters which some are metrics and other counters. Most metrics are using 3 or 4 decimals places while counters whole numbers. We want everything to have 4 decimals places since the data is aggregated by another tool which requires that structure of 4 decimals places. Is there a way to do this without affecting the core of the driver/other implementations? Something similar to DynamicUnits or applying and information template perhaps?
Geovanny Galeano [SLC] [DevOps Advocate] Selected answer as best 27th March 2023
Geovanny Galeano [SLC] [DevOps Advocate]820 Posted 27th March 2023 0 Comments
The customer was ok with making all the metrics uniformed since there was no way to manipulate the decimals after start up.
