Is there a way to get users from Dataminer and then allocate alarms to any one of them?
Solved912 views26th June 2025LCA
Apurva Tandon [DevOps Advocate]1.73K 31st January 2025 0 Comments
I have set of alarms shown on LCA, wherein I want to have a button which will show the list of users present in dataminer and then on selection that alarm will be taken by that person, i.e take ownership
How can I achieve this functionality?
And where we can see the the owned alarms in cube?
Flavio Meneses [SLC] [DevOps Enabler]1.33K Posted 3rd February 2025 2 Comments
Hi Apurva,
I do not believe that what you are trying to achieve is currently possible. With today's features, we expect that a user takes ownership, and we are not able to set the ownership of an alarm to another user. Nevertheless, let's wait for a colleague to confirm or propose an appropriate solution for this.
Nevertheless, for future reference, to retrieve the list of DataMiner users, you can use the "Get Info" message with the type "Security Info". Please be careful when using SLNet messages directly, as this can lead to undefined behavior. Additionally, such messages are subject to change in future releases.
To display only the owned alarms, you can open a new alarm card and select "My Active Alarms" under the "Show Current Alarms" section.
Hope this helps!
Apurva Tandon [DevOps Advocate] commented 4th February 2025
Is there a method which I can trigger to get my active alarms?
Flavio Meneses [SLC] [DevOps Enabler] commented 4th February 2025
I do not believe we have a method in the IEngine for this. However, it can be accomplished using an SLNet message.
AlarmFilterItem filterOwner = new AlarmFilterItemString(
AlarmFilterField.Owner,
AlarmFilterCompareType.WildcardEquality,
new[] { "<user name goes here>" });
var request = new GetActiveAlarmsMessage();
request.Filter = new AlarmFilter(filterOwner);
var response = engine.SendSLNetSingleResponseMessage(request) as ActiveAlarmsResponseMessage;
