Is there a limitation of users connected to the Dataminer cube?
Solved1.60K views18th January 2021
Javier Gordon30 18th January 2021 0 Comments
Good Afternoon,
We want to know is there a limitation of users connected on the Dataminer cube? Or are the connections to the dataminer cube unlimited?
Javier Gordon Selected answer as best 18th January 2021
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 18th January 2021 1 Comment
Hi Javier, I believe a similar question was already asked. Maybe you can find the information that you need over there?
Javier Gordon Posted new comment 18th January 2021
Javier Gordon commented 18th January 2021
Hi Jarno, thanks for the info! That was what we needed to know!
Regards
