Is it possible to use SAML via Azure instead of Active Directory in DM for adding users and groups?
Solved2.17K views15th March 2023Active Directory Azure AzureAD SAML user access
8
Ladan Razeghi [DevOps Catalyst]1.09K 15th March 2023 0 Comments
We are working with different region and creating active directory users and groups is not one of the process in some regions. Is it possible to use SAML instead of active directory to add users to DM?
Ladan Razeghi [DevOps Catalyst] Selected answer as best 15th March 2023
Bert Vandenberghe [SLC] [DevOps Enabler]10.12K Posted 15th March 2023 1 Comment
Hi Landan,
You can indeed use SAML to integrate with an identity provider like Azure AD. I would even recommend it, because then you can leverage e.g. MFA and conditional access to improve security.
This is documented here: Configuring external authentication via an identity provider using SAML | DataMiner Docs (this page also includes the specifics of Azure AD a bit further down that page).
To add users, you can either use auto-provisioning (=any authenticated user coming in, which is not known yet in DataMiner, will be added to a default group), or you can pick and choose the users or groups to be added. For the latter, DataMiner needs to be able to retrieve the users and groups, and this is documented in the following section on the same page: Configuring external authentication via an identity provider using SAML | DataMiner Docs
Bert
Ladan Razeghi [DevOps Catalyst] Posted new comment 15th March 2023
Ladan Razeghi [DevOps Catalyst] commented 15th March 2023
Thank you. I’ll go through and will try this
