Is it possible to use an ArrayOptions tag with an index different than 0?
Solved3.07K views24th June 2021driver development services
Edson Alfaro [SLC] [DevOps Advocate]1.76K 23rd June 2021 0 Comments
Hi all,
In a protocol, a user found a table with an ArrayOptions tag different than 0:
When creating a service using parameters from that table using the primary key as index, the parameters never show at the service:
Is it possible that a wrong definition in the table triggers this miss behavior?
Also, this DMA version is 10.1 CU4, the user still has 9.0 where it is working.
Thanks.
Edson Alfaro [SLC] [DevOps Advocate] Selected answer as best 24th June 2021
Leander Druwel [SLC] [DevOps Member]2.11K Posted 24th June 2021 1 Comment
Hi Edson,
As far as I know, it is surely possible to use an ArrayOptions tag with an index different from 0. The index attribute defines which column contains the primary key. The column containing the primary keys must be of type 'String'.
More info can be found on DataMiner Development Library
I would expect the service to work if you specifically choose for the primary key instead of the display key in the service. A possibility would be to check the service.xml file also, to see if you find the IncludedParameter with an index including the ^pk^, as that indicates the reference to the primary key.
Edson Alfaro [SLC] [DevOps Advocate] Edited comment 24th June 2021
Edson Alfaro [SLC] [DevOps Advocate] commented 24th June 2021
Hi Leander,
In both cases the service.xml file looks good:
****Working****
Arrayoptions in table = 0
IncludedParameter id=”404″ index=”^pk^Interface_3″ included=”1″
****Not working****
Arrayoptions in table = 3
IncludedParameter id=”404″ index=”^pk^Interface_5″ included=”1″
